Please help! OMP
Old Apr 20, 2008 | 02:23 AM
zoltrixsony's Avatar
Please help! OMP
Hi guys.. i have a series 5 jspec.
i tested the omp and i definitely have a short.
So today i decided to remove it. But i cant!!!!!
I took all 4 banjo bolts off and the 2 bolts on top of the OMP. Is that everything??
anything im missing?
PLease any help would be good.
thanks
-zol-
Old Apr 20, 2008 | 04:22 AM
pdtaylor18's Avatar
depends if this has been off before, some people dont rely on gaskets alone and smother the faces with sealant, it could just be glued together dependant on what they use. I never actually took mine of but i did replace the entire oil tubes with some I made, some were very hard and brittle and one even had a hole in it due to some incorrect routing and was fretting.
Old Apr 20, 2008 | 08:25 AM
so just to confirm.. ive taken off all the necessary bits for the omp to come off??
can i just try tug it off now?
also.. not sure if this is a stupid question or not.. i got a 2nd hand ecu. Its a RE Amemiya redom standard ecu. So i was wondering will this ecu still go into limp mode due to a disconnected OMP?
thanks in advance
-zol-
Old Apr 20, 2008 | 09:24 AM
HAILERS's Avatar
HAILERS
I'd take a large hammer and chisel to it. Hit it hard and pry it off. Or maybe remove the bolt on the bottom also. One or the other.
Old Apr 20, 2008 | 02:42 PM
whereiscarmensandiego's Avatar
a standard ecu will go into limp mode no matter what just leave the omp pluged in and tuck it away somewhere and ziptie it
Old Apr 21, 2008 | 07:37 AM
where abouts is the bolt on the bottom. Is it closer towards the fan or the engine?
-zol-
Old Apr 21, 2008 | 03:12 PM
texFCturboII's Avatar
version 2.0
it's towards the engine, it's there, use them fingers and follow the OMP back until you feel it!
Old Apr 21, 2008 | 05:51 PM
HAILERS's Avatar
HAILERS
Ah, man. Your going to undo the bolt instead of using the chisel and hammer. Your no fun at all.
I have NEVER seen a series five OMP in real life. I just looked in the LUBRICATION section of the FSM and saw a picture that showed two bolts on top and one on the bottom. Towards the engine side.
I recommend buying a inspection mirror at the auto store and LED Flashlight so you can see it.
Old Apr 21, 2008 | 07:10 PM
version 2.0
Well, if he was removing the system, then chisel away! lol.
You may have to get under the car to get to it, I had to jack up the front end to comfortably/ more easily get access to the bolt, it is a giant pain to get to, but it is there!
Old Apr 22, 2008 | 03:21 AM
thanks for the replies guys..
I got the OMP off. It was 3 bolts. 2 on top, 1 on the bottom. I ended up taking everything in that corner of the engine bay off just to get to that bolt.
the FSM actually only showed one bolt connecting the OMP to the engine. That is why i asked here on the forum.
-zol-
Old Apr 22, 2008 | 05:44 PM
HAILERS's Avatar
HAILERS
I looked in the series five Lubrication section, page D-9. I blew the view up with Acrobat and it showed me three holes in the pump. Two upper, one lower. Just FYI.
Old Apr 22, 2008 | 06:15 PM
89_Rx-7_GTUs's Avatar
Why would you take of the OMP? I was wondering?
Old Apr 22, 2008 | 07:32 PM
blackball7's Avatar
please check out this thread. it has helped me and many others as well.
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/s5-mop-ecu-failure-diagnosis-710938/
Andrew7dg
Aug 6, 2017 01:41 PM
lnlreaper
Sep 27, 2015 09:59 AM
