glowing cats, are they clogged?
Old Apr 17, 2008 | 07:29 PM
eightysevenjunker's Avatar
i started it earlier today and it ran fine..about 2 hours later i go and start it and it wouldnt rev over 3700-4400 rpm it would hesitate and eventually go higher but slowly. then theres smoke coming thru my shift so i took the boot off (its ripped and fucked up) and i see a red glow..HOLY **** my converters and presilences are glowing ****** red! clogged perhaps? and why do they run fuel lines right next to them? lmao
Old Apr 17, 2008 | 07:32 PM
btw i also have a minor exhaust leak..
Old Apr 17, 2008 | 10:56 PM
311unity13B's Avatar
That's JDM tight, yo
nice, you are from lancaster, i am originally from York/Dallastown...anyways, glowing cats usually indicate you are running rich...as far as i know...someone else chime in?
Old Apr 17, 2008 | 11:23 PM
1SWEET7's Avatar
Now With 10th AE Fun!
I would say yes they are clogged and not working. Take it off, and get it replaced or gut it out. I had the same thing happen to my car when I first got it.
Old Apr 18, 2008 | 08:42 AM
bikeboy23332's Avatar
they run hot but if you think there clogged take them out
Old Apr 18, 2008 | 12:53 PM
Molotovman's Avatar
Ban Peak
If they're stock cats with 169K miles on them. Get a new cat...........
If the cat is fairly new, check your timing.
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
