NewB: Help, Oil Pressure Guage??
Old Apr 16, 2008 | 03:08 AM
gruff's Avatar
Hellp!!! my oil pressure guage hits the roof....its making beep noise when making a turn and flashes with the red Oil icon. How do i Fix this problem??? anyone know how to fix this problem?
Old Apr 16, 2008 | 07:39 AM
HAILERS's Avatar
HAILERS
Your low on oil. Use the dipstick.
Oil pressure gauge has zip to do with low oil light. The sensors output wire sounds like it's grounded to........gnd.
Old Apr 16, 2008 | 10:47 AM
well uhhh's Avatar
I wanna go fast
^ you could at least help out a little. What's worse? a NEWB asking a question that has been covered, or someone who is familiar just posting to search. you aren't helping a damn thing. i personally spent a few hours searching for a resolution to this to no avail, its pretty hard if he doesn't know the terminology.
The oil press. gauge doesn't ground to ground, instead it goes to a condenser (little black box) that should be mounted on one of the slave cyl. bolts. The longer you leave it grounded directly to the ground, the more likely it is that you have burned up your gauge. Make sure your ground wire hasn't shorted, directly to ground.
Old Apr 16, 2008 | 11:56 AM
HAILERS's Avatar
HAILERS
Your gauge is honked up permanently if it's been gnd'd for over a few seconds. Unrepairable.
Old May 4, 2008 | 09:42 AM
hhn2002's Avatar
what can i do if i lose the little black box but want an oil pressure readout? is getting another one the only way?
Old May 4, 2008 | 10:04 AM
Aaron Cake's Avatar
Engine, Not Motor
Little black box? If you are referring to the CPU, the oil pressure gauge is independent. It will run without the CPU.
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
