Canadian Forum Canadian users, post event and club info here.
Rx7 FD help
Old Apr 11, 2008 | 07:41 PM
Initial_fd3s's Avatar
Rx7 FD help
Hey, i notice the rpm gauge on my rx7 has these random bounces and was woundering if any of you know how to repair it?
Old Apr 11, 2008 | 11:01 PM
misterstyx69's Avatar
Retired Moderator, RIP
I know that the Sec gen RPM Gauge runs off Trailing..if the Fd Runs the same,then I would check the Plug wires and the Plugs themselves..fouled trailing plugs will alter the Tach...then again I have been wrong before!
Old Apr 11, 2008 | 11:06 PM
londonmazda's Avatar
Wouldn't be the plugs, the signal is still being sent to the plugs regardless.
my bets on the cluster being a bit funky.
Old Apr 12, 2008 | 10:16 AM
the cluster? hmmm i dunno what would i have to do to replace it?
Old Apr 12, 2008 | 10:52 AM
ScrappyDoo's Avatar
Search the term "Tach" & "bouncing" in the 3rd gen section and you'll get alot of informative threads. Read them all and you'll see that there are grounding issues and points that often need to be re-soldering on the cluster. If you still don't have an answer post a more specific question based on what you learned by reading in the 3rd gen section and I am sure you'll get some help.
Old Apr 12, 2008 | 02:15 PM
k thanks alot man
Old Apr 12, 2008 | 04:45 PM
and if the Plug doesn't Spark?..Try to get teh 2nd gen tach to work with Fouled plugs..you will see what I mean..
Old Apr 12, 2008 | 10:44 PM
Crymson's Avatar
My tach would stick at about 2,500 rpm, then break free at about 6 then shoot out. I got a cluster off ebay, swapped the tach, and no problems since. Easy as pie.
Old Apr 13, 2008 | 09:09 AM
rd_turbo's Avatar
ERTW
+1 on the cluster being the issue....there are a couple of guys down south who've posted in the 3rd gen section that they offer a repair service if you send it in. If you ask, I'm sure someone will chime in.
Old Apr 17, 2008 | 12:32 AM
alright thanks alot guys
Th0m4s
Feb 26, 2019 02:04 AM
