Sponsored by: CARiD
need second opinion
Old Apr 8, 2008 | 05:30 PM
blackcloud's Avatar
blackcloud
need second opinion
93 fd wont start. ran poorly stalled and wouldnt start back. found faulty spark plug wire repl. wires and plugs and still wont start. a guy said to pour tranny fluid into the intake and turn it over till it will start. burn it off and then change plugs and things should be ok. he seems to beleive apex seals are seized. has anybody tried this before? car has not been started in 4 months. havent checked compression.
Old Apr 8, 2008 | 05:52 PM
to_slow's Avatar
Yes do the trany fluid trick. Make sure it sit for at least 24h to let it soak in.
That might fix it, if its carbon build up. If it does not fix it. You might want to do a compression test.
Hope that helps
BLK 93
Sep 28, 2015 01:45 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
mulcryant
Sep 9, 2015 05:24 PM
