Dynamic chamber stays cool!
Old Apr 26, 2002 | 07:41 AM
Samps's Avatar
I went for a lil drive yesterday and I was gettin on it preaty hard for about an hour. Well anyways, when I got back to my house, I popped the hood to inspect for any damage I might have done in my adventure. Thankfully I found no problems. But as I was inspecting, I rested my hand on the dynamic chamber and to my surprise, it was very cool to the touch. It amazes me that this chunk of aluminum directly above the motor could stay cool after an hour of hard driving. It got me thinking about the effectiveness of a cold air intake. It also made me wonder why a top mount intercooler on a turbo would be such a horrible place to locate it. Somehow this thing stays cool, almost a cold feeling. I have done the throttle body mod; but I can't see that making that big of a difference. Oh well; just my thoughts.
Old Apr 26, 2002 | 08:19 AM
Wankel7's Avatar
Haven't we ALL heard this
Turbo or non turbo?
James
Old Apr 26, 2002 | 08:29 AM
pd_day's Avatar
Spoolin'
dynamic chamber = VDI = series 5 NA manifold
Old Apr 26, 2002 | 08:41 AM
Samps's Avatar
The location above the motor not being hot is the main point.
Old Apr 26, 2002 | 08:46 AM
pd_day's Avatar
Spoolin'
Do you have any other cooling mod other than the TB mod? Stock everything else?
Old Apr 26, 2002 | 08:59 AM
Samps's Avatar
cold air box, and finger chopper electric fan.
Old Apr 26, 2002 | 11:25 AM
blu_gxl's Avatar
SAMPS you know why it's cold still don't cha dude it's the porting!! your flowing more air due to the tb mod and porting of the dynamic chambe mine used to be pretty hot after a drive now i can sit in traffic for an hour and the thing is not cold but cool to the touch i always rest my hand there because it's cool
james
Old Apr 26, 2002 | 05:05 PM
Wankel7's Avatar
So what is the thing called after the trottle body?
James
Old Apr 26, 2002 | 05:26 PM
Bambam7's Avatar
I came, I saw, I boosted.
Unless you are sucking hot air in- the Dynamic Chamber should always be cool.
It will usually be a good bit cooler than the intake air being sucked in the filter.
Huh?? I'll explain-
The reason for this is the transition between atmospheric pressure and vacuum at the throttle plates.
It exhibits the same properties as an air conditioner.
You compress air- it heats up.
You expand, or evacuate the air, and it will cool- as you are drawing energy from it.
This is why coolant goes around the throttle body- it prevents the throttle plates from actually icing up!
It is constantly getting this flow of cooling air.
Old Apr 27, 2002 | 10:35 PM
Samps's Avatar
Thanks!
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
