T-78 Leaking oil, why?
Old Mar 20, 2008 | 10:07 PM
RedBaron7's Avatar
It's smog legal
Exclamation T-78 Leaking oil, why?
I just had the whole turbo rebuilt. What would cause it to leaking oil on exhaust housing side? It leaks into the housing, and drips from the clamp and onto the flange on the header. There are no miles on the turbo, just idle only. It has leaked from the beginning of the install....
Old Mar 20, 2008 | 10:49 PM
Busted7's Avatar
Will work for horsepower
Bad rebuild and your asking the wrong people i would be on the phone the the rebuilder!
Old Mar 20, 2008 | 11:16 PM
RedBaron7's Avatar
It's smog legal
I ship it back to majestic turbo tomorrow. Just seeing if anybody had same problem.
Old Mar 20, 2008 | 11:17 PM
RedBaron7's Avatar
It's smog legal
Old Mar 20, 2008 | 11:25 PM
Busted7's Avatar
I have had friends have problems with there rebuilds!
Old Mar 20, 2008 | 11:28 PM
RedBaron7's Avatar
It's smog legal
suggestion on who can fix it, if they don't?
Old Mar 20, 2008 | 11:50 PM
Gohan3rdrift's Avatar
Movie Star
you sure the clamp was tight?
Old Mar 21, 2008 | 08:19 AM
RedBaron7's Avatar
It's smog legal
Yep, tighten all the way down.....
Old Mar 25, 2008 | 11:48 PM
S3DF's Avatar
Is majectic a turbo rebuilder shop or a speed shop/motorsports?
Old Mar 26, 2008 | 12:00 AM
RX794's Avatar
NYC's Loudest FD
I've heard good things about Forced Performance in TX, they've rebuilt a lot of Greddy/Mitsubishi turbos in the past with great success. Here's a link to their website, all the contact information is there: http://store.forcedperformance.net
Old Mar 26, 2008 | 01:02 AM
Turblown's Avatar
Turn up the boost
It may or may not be the turbo.
However rebuilding a turbo is NOT as easy as replacing some seals and bearings.
It takes experience to know if a shaft is worn out, or if there are other areas that will cause problems. Pitting in seal ares, excessive clearances, etc etc.
Old Mar 26, 2008 | 02:17 PM
RedBaron7's Avatar
It's smog legal
Well the people that rebuilt the turbo are saying that the turbo's clearances are to spec, and the turbo is pretty much brand new. I asked then why would it leak. like it does...and it's not just a small leak. They cannot give me a reason why. I just paid for the whole turbo to be rebuilt, new shaft, wheel, seals, etc. They are hinting to me that I must have increased the inlet size and that is what is causing turbo to leak. TOO much pressure they say. But its the same set up I have been running for the last 6yrs, and this is the first time for this issue.
So my next question is, if you can have this problem do to higher oil pressure. I have stage 3 oil mods done by pineapple racing. If anything the pressure should be down from a stock motor do to the mods done.
Any thoughts??
Old Mar 26, 2008 | 02:18 PM
RedBaron7's Avatar
It's smog legal
Turbo rebuilder
Old Mar 26, 2008 | 02:42 PM
iceman4357's Avatar
hmmm...I have had my t78 rebuilt from them and no issues. Are you dealing with majestic in Wako texas or dallas texas?
*I would also check your oil return line!! I had almost an identical issue. Everything looked perfectly fine, but there was a kink in the return line which caused oil to leak inside the turbo. I had to install the turbo and physically feel the return line to feel the kink. Little issues=big headaches! Hope this helps
Old Mar 26, 2008 | 05:17 PM
RedBaron7's Avatar
It's smog legal
Thanks!! I have a couple of things to check
1. Kink in drain hose??(it goes striaght to the block, under the metering pump)
2. Crank case pressure(keep from oil draining)?
3. Oil pressure to high(dont think so, one of the other two)
the turbo is coming back to me by Friday. We will see....
rotor_veux
Sep 3, 2015 07:10 PM
sypath
Aug 16, 2015 12:06 AM
