injector resistance ?
Old Apr 23, 2002 | 06:26 PM
execelon1's Avatar
Question injector resistance ?
i have a steady skip when only holding the throttle steady, no skip during acceleration and a pretty smooth idle at 750rpm . it sounds like a 2cycle motorylcle. like dit dit dit de dit de dit. this is what i have checked so far. crank angle-ok, tps-ok,new plugs, new wires, both coils-ok , water thermo-ok, aws-ok, boost sensor-ok,bac-ok, injectors-?they read 2.3 ohms on the 200 scale and the manual says this is ok from 1.5 to 3.0 ohms for 86-87 models but mine is a 88 vert na 5-speed. when i checked the plugs they were black. the manual says that the resistance for 88"s should be 12 to 16 ohms could this be causing the skip ? i have run MMO in the tank and chevron techron injector cleaner through it so they should be pretty clean. oh i only checked the secondaries. should i install a resistor to compensate so the ecu will read it right, or get new injectors? thanks ex...
Old Apr 23, 2002 | 06:29 PM
RETed's Avatar
Do a basic tune-up before blaming injector resistance for this problem...
-Ted
Old Apr 23, 2002 | 06:36 PM
NZConvertible's Avatar
I'm a boost creep...
Re: injector resistance ?
Not necessarily. Those things are OK for regular preventitive maintainance, but don't come close to a professional clean.
Old Apr 23, 2002 | 09:11 PM
execelon1's Avatar
basic tune-up thanks
-Ted
thanks Ted for replying, i thought i did a basic tune-up = new wires, plugs , air filter , set tps by led lights, set idle by the book. what else do i need to do ?
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
localized
Sep 16, 2015 12:18 AM
