Greddy Gauges
Old Mar 9, 2008 | 02:18 PM
twomucboost4u's Avatar
Always Under Construction
Greddy Gauges
So I was wondering if there is any way to change the color from the original green backlight on the white gauges? Any bulb I can change? Thanks for any info you have.
Chris
Old Mar 10, 2008 | 02:21 PM
Nothin?
Chris
Old Mar 10, 2008 | 02:32 PM
The Griffin's Avatar
Burning up Time
The bulbs are white ,the gauge face has a film on the back that gives it it's color.You could try a different color light/LED if you can find one that fits to see if it will give off another color,that or take apart the gauges and remove the film.The link below gives you an example what your up against.If you remove the film on the white guages you will need to paint the back again with a translucent paint/add film as the flim is a base for the numbers on the front side of the face when the gauge is unlit, unlike the black face gauges like the link below.
https://www.rx7club.com/showthread.p...r%2Ffuel+gauge
Old Mar 10, 2008 | 06:28 PM
Thanks you thats exactly what I needed to see.
Chris
24seven_dada
20
Nov 10, 2018 12:03 PM
Ian_D
Oct 14, 2015 12:31 PM
The1Sun
Sep 15, 2015 04:45 PM
