GTUS turbo
Old Apr 23, 2002 | 01:45 PM
perfect7's Avatar
GTUS turbo
Has anyone swaped a jspec into a gtus? I could be wrong but it should have everything but the harness and ECM?
Old Apr 23, 2002 | 01:51 PM
jmseven's Avatar
Asset is Wealth
You will need the harness and the ECU. The driver side harness is the same. You will need to use your GTU flywheel and clutch assy if you are keeping your tranny.
Old Apr 23, 2002 | 01:56 PM
perfect7's Avatar
I thought the tranny is the same as a TII?
Old Apr 23, 2002 | 02:02 PM
mazdaspeed7's Avatar
mad scientist
The tranny is a regular n/a tranny, except is has the same 5th gear ratio as the TII tranny. Also, the GTUs diff still uses the 7" ring gear of the n/a, just has a 4.3 ratio, and a LSD. The TII's had an 8" ring gear.
jmseven's Avatar
Asset is Wealth
I know that the N/A trannys are different. The part numbers for the flywheels for turbos and N/As are different also.
Old Apr 23, 2002 | 02:09 PM
perfect7's Avatar
The only reason I ask is that i just bought a gtus to build into a soloI car, but i turned down another gtus with a blown motor for $900, and it would be a cool sleeper with a jspec and no badges on the car, and a reg hood..
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
Spriggs
Aug 20, 2015 03:33 AM
