fd intake to fc---how do I it them? h e l p me with my project.
Old Feb 28, 2008 | 03:53 PM
axela's Avatar
Arrow fd intake to fc---how do I it them? h e l p me with my project.
hello,
I both a upper and lower intake with throttle body from a 94 fd.I have a 86 s4 series .how can i fit the intake?please help me .Thanks
Old Feb 28, 2008 | 04:02 PM
The Griffin's Avatar
Burning up Time
The LIM from the FD doesn't fit on the S4 or S5 blocks. You are either going to have to machine an alumium adaptor to bolt the FD LIM on the block or the other(most common) option is to use a S5 TII LIM and either port match the FD UIM to it or make or abtain an adaptor between the S5 LIM/FD UIM. Since your profile says Romania it would probably be easier to have a alumium adaptor machined/made between the FD LIM and S4 block.
There is lots of info on this, if you do a search it should net you some more info(but it's all on the second method I mentioned above).
Old Feb 28, 2008 | 04:09 PM
axela's Avatar
ok,Thanks man,I do have a s5 lim .
so let me see that i understand right.
Now I have a s4 block and need a s5 lim and with a fd uim will work.
right?Between Fd uim and s5 lim will require a aluminium adaptor?what other modifications Do i HAVE TO MAKE?
thanks
Old Feb 28, 2008 | 04:13 PM
Asterisk's Avatar
iRussian
How about "simplifying" the manifolds? I have see this one guy cut and reweld a lot of the stuff on the lower manifold, all kinds of extra crap you dont need, and it looked a lot cleaner withought it all on there.
Old Feb 28, 2008 | 04:17 PM
axela's Avatar
I Like the ideea of simplify the things.can you give more info??
Burning up Time
You can port match the FD UIM to the S5 LIM manifold and not have to use an adaptor, But it's not the best way.But saying that neither is using an adaptor as that increases the length of the runners. The best way of doing it is not using an adaptor and fill welding the FD UIM with aluminum and then port matching to the S5 LIM to keep the inner runners the same shape and diameter(if you don't the inner FD ports will be oval and larger). Just take a S5 TII gasket and match it around the center hole of the FD UIM and you will see exactly what is needed.
By the way this should be in the 2nd. gen section and not here. This is for pictures and non-tech. stuff.Good luck.
Old Feb 29, 2008 | 08:56 AM
MonkeyMagic's Avatar
Stay running...please??
I did that swap. I used a S5 lim with a S6 uim and throttle body on a S4 block. The ports are matched and I am using an adapter between the two manifolds. As far as finding an adapter, I forgot who makes them, but I'll do a quick search.
Attached Thumbnails fd intake to fc---how do I it them? h e l p me with my project.-dscf5242.jpg
Old Feb 29, 2008 | 09:05 AM
On mazdarotaryclub.com, jetpilot made a bunch of adapters. It was about 2 years ago, but try pm'ing him.
On this thread, one is for sale:
https://www.rx7club.com/showthread.p...nifold+adapter
I am sure you can find more if you search.
Old Feb 29, 2008 | 03:06 PM
axela's Avatar
thanks very much man.
risingsunroof82
22
Sep 22, 2015 01:20 PM
newtgomez
Sep 13, 2015 07:39 PM
