Can my engine with hold a 75 shot of NOS
Old Apr 21, 2002 | 07:33 PM
RavenRx7's Avatar
Arrow Can my engine with hold a 75 shot of NOS
I could sell the kit was wha the hell, I'll guess I'll install after a purchase the Apexi PFC. Will the stock apex seals hold up? I will also have to upgrade my intake system.
Old Apr 21, 2002 | 07:37 PM
black99's Avatar
Lurking..................
Personally I don't think it'll hold a 75 shot with twin turbos at least not forever. Sell the kit on ebay..
Old Apr 21, 2002 | 07:40 PM
what exactly is the problem of running nitros in fd? if say a 75shot with enough fuel to back it up, would that be a problem?
Old Apr 21, 2002 | 07:57 PM
vosko's Avatar
Just Call Me Terminator!
you need to richen it up when you shoot the NOS or else it will lean out
Old Apr 21, 2002 | 08:02 PM
RyanREX's Avatar
Killer Turbo Twins
Get a set up where you direct the NO2 into the intercooler like alot of drag racers do. It freezes the core making all the air that goes in cold, kind of like a cold air intake for your intercooler.
Old Apr 21, 2002 | 08:27 PM
to_slow's Avatar
Well what about a 50 shot ? And what about that ic kit you are talking about ?
Thanks
Dan
Old Apr 22, 2002 | 06:39 PM
RavenRx7's Avatar
it's a 50 or 75.. I seem to believe if i have my car tuned on a wideband with the PFC --there shouldn't be a prob.
Old Apr 23, 2002 | 06:52 AM
Rotary Master
just remember after the car is tuned for the NOS, it will be running super rich all the time, unless you upload different maps.
Old Apr 23, 2002 | 09:04 AM
Gun's Avatar
Gun
Look here for info on a 75 shot install.
http://www.rx7turboturbo.com/robrobi...us_install.htm
Looks like it works rather good, the Zex system is a "smart" system so it regulates the fuel pressure for you. I'm going to look in it probally.
later Gun
Old Apr 23, 2002 | 09:09 AM
JONSKI's Avatar
5yr member, joined 2001
I believe it's N2O, not NO2. The latter would be nitrogen dioxide, which would be very hard to make, assuming it were possible at all.
Old Apr 23, 2002 | 09:58 AM
jmo87's Avatar
or you could sell it and find a way to make real horsepower. IMO
Old Apr 23, 2002 | 10:44 AM
95R2-89TII Ground Zero's Avatar
Banned
Very true, but if you have upgraded the fuel system, then you could link the NOS into the ECU as to richen the mixture upon delivery.
Old Apr 23, 2002 | 12:06 PM
Gun's Avatar
Gun
I think I would stay with a kit like the Zex kit used by Rob in his car. It's a 75 shot and he had no problems with it. Just make sure your cars in good working order befroe you install the nitrous. He recommended an upgraded fuel system, so I wouldn't use the stock system. As I posted before here's the link again
http://www.rx7turboturbo.com/robrob...ous_install.htm
As long as everything is done right then it shouldn't be a problem.
later Gun
Old Apr 23, 2002 | 10:36 PM
zooq's Avatar
if you used a fogger (wet) system there will be enough fuel for the nitrous only, so you will not have to run a different fuel map. and you can controll how much fuel is going in by changing the jet size
elfking
Aug 19, 2015 09:48 PM
smikels
Aug 18, 2015 01:26 PM
