CA Emissions
Old Apr 21, 2002 | 04:21 PM
.:Adam GS:.'s Avatar
Unhappy CA Emissions
I got my RX smogged a few months ago, it failed the first time, and they did some carb tuning and then it passed, but barely. What I was wondering is, If i put a new intake, an exhaust with free flowing cat, and a new carb, would I fail smog horribly?
Is there anything I can do to reduce emissions?
What about ATF?
Thanks
Old Apr 21, 2002 | 04:40 PM
eddierotary's Avatar
back with rotaries
if you almost fail with everythinng stock imagen with all the thing that you want to do.
Old Apr 21, 2002 | 04:42 PM
Eddie, that's my point.
Old Apr 21, 2002 | 05:28 PM
MarkPerez's Avatar
Tennis, anyone
you know it's hard to choose, performance VS ca.
i totaly understand what is going through your head.
and it's hard to say that with those mods.you will pass
so all i have done to my 7 is a hi-flow cat. keep in mind
that changing parts at smog time sucks,,,i'm just about
readdy to buy and install a 13bt.i'm not going to under take the project untill i'm certain that i've got the smog
problem taken care of
Old Apr 21, 2002 | 05:36 PM
Manolis_D's Avatar
There was a discussion on high-flow cats awhile ago, i think the only one that registered significantly higher emissions-wise was the N-Tech cat. Intake shouldn't hurt emissions at all as far as I know. With respect to the carb, did you mean new stock carb, or a bigger one? If the carb is bigger, i'd imagine that HC would probably go up a bit-- it seems that the bigger carbs are harder to keep in tune sometimes.
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
