Can i do a bridge and a peripheral port
Old Feb 9, 2008 | 09:12 PM
lizardsbba's Avatar
titles kinda self explanatory. if so why or why not. and whats better or what should i do and can i do it myself like buy a template.
Old Feb 9, 2008 | 09:42 PM
61620B's Avatar
Lots of practice for both and good machinery.
Also need some good tools.
Old Feb 10, 2008 | 03:43 AM
RETed's Avatar
You can but why?
BP gives you advantages due to it's duration and early opening.
The PP gives you both with a LOT more.
Unless you're talking about a really tiny PP?
-Ted
Old Feb 10, 2008 | 10:04 AM
lizardsbba's Avatar
so i should just do a pp? were can i get a template for that and about how hard is it?
Old Feb 10, 2008 | 10:55 AM
RETed's Avatar
If you're asking how to do it...don't.
-Ted
Old Feb 10, 2008 | 11:12 AM
ericgrau's Avatar
Clean.
Most people do a street port or bridgeport because it's a lot easier. But a peripheral port makes more power than a bridgeport. A street port is still popular in spite of lower power because it doesn't have the practical problems that a bridgeport or peripheral port has. That's why it'd be nigh impossible to see a bridgeport or peripheral port in a factory car, whereas larger and larger "street ports" are coming with each new rotary model.
Old Feb 10, 2008 | 12:15 PM
Black91n/a's Avatar
Generally speaking, NO. A PP has tons of volume and timing already, you probably can't make use of any more from the side ports.
If it's for street use then don't PP. To get it quiet enough for street use you'll be severely choking it and it'll be way down on power. At that point you'll be making about as much as you would with a good bridge, where the bridge would be a lot cheaper.
Do yourself a favour and do a lot of research on both before doing anything about it.
Old Feb 10, 2008 | 03:14 PM
t-von's Avatar
Rotor Head Extreme
-Ted
LOL You crack me up Ted.
Old Feb 10, 2008 | 06:55 PM
Zero R's Avatar
Just in time to die
There's a few people out there running combo bridge, P-Port's they must have some secret figured out
Old Feb 10, 2008 | 07:16 PM
Black91n/a's Avatar
Well there's a semi-PP, then there's a PP. With the semi it's just a very small peripheral port in addition to the side ports, not like a traditional full sized PP. You probably couldn't get a 13B to run, or at least not well with PP housings and bridgeported irons. You probably could never get enough exhaust port to match it.
Old Feb 10, 2008 | 07:22 PM
diabolical1's Avatar
bingo! if you want to run a combination, you'll have to compromise on the size and timing of the peripherals. the main two reasons i see are both for the sake of getting the motor to run right and also, the gross complication of getting/making an intake manifold. however, getting appropriate exhaust, as mentioned earlier, will also become an issue if you're going to try to run full-sized peripherals with the side-ports still functioning.
Old Feb 10, 2008 | 07:27 PM
-Ted
i agree with Ted.
Old Feb 11, 2008 | 06:43 PM
t-von's Avatar
Rotor Head Extreme
You must be talking about Judge ITO. He was running a full bridge and semi PP on his drag RX3 (I think). It was a straight runner set-up and made PP numbers to the rear wheels. The thread is over at Nopistons.
Old Feb 12, 2008 | 09:48 AM
rotaryinspired's Avatar
He could be talking about people not on this board and who don't want to show off their set ups.
Old Feb 12, 2008 | 01:33 PM
Zero R's Avatar
Just in time to die
He is one yes, and to me a P-port is a P-port regardless of size. Combo-port, semi P-port, etc. are all backyard descriptions to a solution. As example, I would say ITO runs a combo-port, you would say he runs a bridge port and a semi p-port. Who is wrong here?
~S~
Old Feb 12, 2008 | 02:52 PM
Black91n/a's Avatar
Well there really needs to be a better description than just peripheral port in my oppinion, because that offers no information on the timing, positionning or size of the port. It'd be like calling all side ports simply side ports. Not very informative. See what I mean?
To me a PP means HUGE ports, and if they're something smaller and auxiliary there should be some sort of descriptive adjective associated with them to convey that information.
Old Feb 12, 2008 | 03:07 PM
Zero R's Avatar
Just in time to die
Here's a simple solution "I run small peripheral ports" there you go , trying to say timing should be included goes under the same argument as we've been having.
Combining a P-port and a side port would only make sense to be called a combination port or combi-port. You can't really have a semi p-port if you think about it. It either has a P-port or it doesn't.
~S~
Old Feb 12, 2008 | 06:15 PM
t-von's Avatar
Rotor Head Extreme
~S~
No one!
Old Feb 12, 2008 | 06:21 PM
t-von's Avatar
Rotor Head Extreme
Well if it were me, I would just call it a bridge PP engine or a half bridge pp engine. I think most in the rotary comunity would know exactly what I meant. If it had regular side ports, then I would just call it a side/pp engine.
That's just my opinion.
Old Feb 12, 2008 | 06:29 PM
13B-RX3's Avatar
7s before paint!!!
Old Feb 12, 2008 | 10:36 PM
ultimatejay's Avatar
A p-port is an intake port directly in the side of the rotor housing- regardless of size and timing it's a p-port. A semi-pport is a combination of both the p-port and the normal side ports in the irons. Alot of the top dogs are running this combination because I think it gives the power good low and top end. Most I have seen have a reletively small p-port with a big bridgeport like the semi- p-port Allen posted above.
Old Feb 13, 2008 | 09:38 PM
t-von's Avatar
Rotor Head Extreme
^ Yep that's Judge ITO's work. I think someone in the 20b section maybe trying to duplicate that set-up.
danielbradley2
11
Sep 28, 2015 10:44 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
scissorhands
Sep 16, 2015 01:25 PM
