Power FC has anyone used the fd coils on their fc?
Old Jan 23, 2008 | 11:03 PM
silverfdturbo6port's Avatar
500+hp club
has anyone used the fd coils on their fc? has anyone had any problems with the fd coils?
Old Jan 24, 2008 | 02:52 PM
siguy2k's Avatar
SLEEPER
Why dont you just do the coil mod off of Banzai racing? You need two trailing coils and follow the write up on there.
Old Jan 24, 2008 | 04:01 PM
arghx's Avatar
rotorhead
there's no reason to use FD ignition components in an FC.
Old Jan 24, 2008 | 08:43 PM
500+hp club
well
well yeah i see the mod YOU HAVE TO DO in order to use the stock ignition with the power fc but i like the clean look of a fd engine that has everything tucked away i just want to know if anyone has done it.....
Old Jan 25, 2008 | 05:04 AM
Banzai-Racing's Avatar
Rotary Specialists
We have the FD coils in our Vert 13b-re project, simply because there is space to mount them under the TB. To install the coil pack requires you to wire in an FD igniter, there is a how-to on our website for this also. Unless you have all the parts and connectors we do not recommend this install, it is a lot more complex, with absolutely no performance gains... The only reason I did it was to prove it could be done and clean up the engine bay a bit.
Additionally the FD coils have been known to overheat and fry, this is why you will see the common upgrade for the FD is to install an FC leading coil.
Old Jan 25, 2008 | 10:55 AM
cewrx7r1's Avatar
Eye In The Sky
If you do use the FD coil pack, remove the leading coil and replace it with the FC leading coil. The FC leading coil is better than the FD leading coil. Only requires a little cutting/grinding and glues it in place with much silicone.
I did this to my FD pack and still can swap the FD coil back if needed.
RuffRx7
Oct 1, 2015 03:08 AM
GKW
Sep 28, 2015 04:34 PM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
