Gurgling sound.. ?
Old Jan 17, 2008 | 12:37 AM
zinch's Avatar
Gurgling sound.. ?
Sorry I haven't had time to search with school starting and all.. But I've noticed that every time I start to push on the gas I hear a "gurgling" or "sloshing" sound from the passenger front. I hear it kind of slosh backwards when I accelerate, but I can hear it if I just push the gas down in neutral. Any ideas on what this could be?
Mike
Old Jan 17, 2008 | 01:07 AM
YOUWSH's Avatar
Have you tried checking your coolant level? I'm almost certain its low because if it was full you would not hear the coolant sloshing back and forth. You shouldn't really hear a gurling sound until after you've shut off the engine.
Also try burping out the air pockets in your coolant system as well.
Start with those two things and see what happens.
Old Jan 17, 2008 | 07:15 AM
DaveW's Avatar
Racecar - Formula 2000
Mike
That is probably the sound of air moving in the heater core, so another vote for "burping."
Old Jan 18, 2008 | 12:03 AM
sO IT is normal for the car to gurgle when shut off ?
Old Jan 18, 2008 | 12:58 AM
YOUWSH's Avatar
My car always makes a sound after I shut her off. Its hard to describe the sound but its definately coming from behind the air pump/filler cap area. It is NOT a boiling/bubbling sound, so if you get this sound you definately need to check your coolant level.
I asked this same question to a guy who had a near new 2002 FD and believe it or not, his car made this same sound and I was told it was 'normal'.
duckyjp
Mar 23, 2004 10:48 PM
mb7
Mar 16, 2003 08:22 PM
Amur_
Feb 19, 2003 10:06 PM
GoRacer
Jul 16, 2002 10:24 PM
Donovan
Oct 3, 2001 07:59 PM
