Xtreme rotary oversized studs.
Old Jan 11, 2008 | 05:52 PM
13B-RX3's Avatar
7s before paint!!!
Does anyone know if the thread size and pitch are the same as the stock bolts (at the front iron) or do you have to drill and tap the front iron?
TIA
Old Jan 11, 2008 | 05:56 PM
frode's Avatar
You have to drill and tap.
Old Jan 11, 2008 | 06:15 PM
Viking War Hammer's Avatar
*** Bless The USA
Search through a pile of head bolts, you're bound to find something that fits
Old Jan 11, 2008 | 06:25 PM
crispeed's Avatar
'Tuna'
Is that what Abel told you!
Old Jan 11, 2008 | 06:27 PM
Mahjik's Avatar
Mr. Links
They make 2 different sizes. One size is slightly larger than the stock studs but do NOT require any machining. The other set does require machine.
Old Jan 11, 2008 | 06:31 PM
*** Bless The USA
no, I only talked to him about a waterpump adapter.
The headbolt thing is all me baby !
Old Jan 11, 2008 | 06:36 PM
crispeed's Avatar
'Tuna'
You know I was joking right?
Old Jan 11, 2008 | 06:43 PM
*** Bless The USA
of course..................
Old Jan 11, 2008 | 06:47 PM
13B-RX3's Avatar
7s before paint!!!
Yeah, i am going to go with the oversized ones. I am going to need all the help i can get. On the other hand Eric is going to use some grade 5 allthread.
Old Jan 11, 2008 | 06:50 PM
*** Bless The USA
Lowes has a great selection. Those coupled with a few C-Clamps should work wonders
Old Jan 11, 2008 | 06:59 PM
crispeed's Avatar
'Tuna'
Don't forget the cordless drill also!
Old Jan 11, 2008 | 07:28 PM
Zero R's Avatar
Just in time to die
'Fish'
~S~
Old Jan 11, 2008 | 07:36 PM
crispeed's Avatar
'Tuna'
Originally Posted by Zero R
'Fish'
~S~
'Tuna'
Old Jan 11, 2008 | 08:22 PM
Zero R's Avatar
Just in time to die
Is good to eat?
~S~
Old Jan 11, 2008 | 08:59 PM
13B-RX3's Avatar
7s before paint!!!
What is the size and the thread pitch that you have to chance the front iron to?
Old Jan 12, 2008 | 12:07 AM
61620B's Avatar
studs thread
I use this set on my drag car.The pitch thread is 1/2-20.You have to be careful
when you drill into the face with the right drill bit because if you don't use the
right tooling you can just throw away your good iron.Or you can be creative and
just drill through the face and put a longer stud with nuts on both ends.This was a
desperate move i did when i messed up my last good iron for a race.
Old Jan 13, 2008 | 01:03 AM
abelrx8's Avatar
the stud kit works great if machined properly. i have done a couple of engines 2 and 3 rotor. they are done on a cnc that is the only way for them to come out perfect and maintain tolerances so they do the job they were made for.
Old Jan 14, 2008 | 11:36 AM
philiptompkins's Avatar
dude, that is bad ***. I never thought about that.... how did it hold up? do you still use that setup?
Old Jan 14, 2008 | 05:38 PM
crispeed's Avatar
'Tuna'
Not to mention when the time comes to change a housing the CNC will match the previous machine work done right?
Something not possible when using non automated process.
Old Jan 14, 2008 | 05:42 PM
crispeed's Avatar
'Tuna'
That's how they are done on the 3-rotor anyway. The 13B REW/RE and 20B front housings are the only ones casted from factory to allow this to be done easily. It's nice to have nuts on both ends of the studs.
Old Jan 23, 2008 | 06:30 PM
13B-RX3's Avatar
7s before paint!!!
Old Jan 25, 2008 | 04:46 PM
mazpower's Avatar
Slizzard sippin sizzurp
A CNC isn't the only way. I've got a machinist that has finished mine using a mill & various "tools" he's created, like a "bushing" insert that uses the reamed rotor housing holes to guide the correct drill bit for the front iron. But then again this guy has been a machinist for over 25 years and works at a company that uses CNC mills & lathes to modify guns & rifles for the S.B. Sheriff's department and the Twentynine Palms Marine Base. He's got the process down where the engine will go together, albeit a little snug, at .503" on the holes...we ended up taking it to .508" as recommended by the kit. For those who don't know the studs themselves are .500"...we're talking the thickness of a piece of paper in difference.
As for the rotor housings, he made the tooling as such that it will take 15 minutes to get the rotor housing to match the rest of the engine using his mill and various piloted reamers he's custom made.
Old Jan 25, 2008 | 07:41 PM
slo's Avatar
slo
registered user
How much does he charge you for this?
anyone ever though of just doing three studs on the spark plug side and 2 on the exhaust side, or some other combination, instead of all or all but one?
Old Jan 26, 2008 | 03:37 PM
crispeed's Avatar
'Tuna'
Most people I know only use four studs. You can buy the studs individually from PR.
Old Jan 26, 2008 | 07:40 PM
slo's Avatar
slo
registered user
they look like gigantic head studs
