Dumping fuel
Old Jan 11, 2008 | 12:28 PM
gegger's Avatar
Angry Dumping fuel
My 94 outomatic is dumping fuel and I'm about to give up and swap my rotary for a V-8! The fuel meter jumps to rich as soon as I touch the excellerator after warmup. It won't pass emissions and runs in safe mode most of the time. The TPS was an immediate suspect but it checks out per manual specs. I've checked out all sensors, I've replaced all of the solenoids, the precat has been replaced with a downpipe, injectors were rebuilt, and I swapped the ECU for another used one from EBAY which was no help. The fuel pressure is constant so I don't think it's the pump or regulator. Any ideas?
Old Jan 11, 2008 | 12:35 PM
tiger18's Avatar
Have you tried pulling the ECU codes to see if theres any electrical faults??
Old Jan 11, 2008 | 03:26 PM
bryant's Avatar
bryant
before you ask
http://www.fd3s.net/engine_codes.html
Old Jan 11, 2008 | 11:37 PM
gegger's Avatar
No codes on the on board diagnostics!
Old Jan 12, 2008 | 02:21 AM
Busted7's Avatar
Will work for horsepower
Check temp senders, and map senser.
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
