Naturally Aspirated Performance Forum Discussion of naturally-aspirated rotary performance. No Power Adders, only pure rotary power! From the "12A" to the "RENESIS" and beyond.
My bridgeport project.
Old Jan 6, 2008 | 10:52 PM
ultimatejay's Avatar
Just got my motor together this weekend. Using RB race 12a rebuild kit with the carbon apex seals. I also used their exhaust port template and cleaned the existing b-ports up a little. Engine should be fired up this coming weekend and is going into my rx2 with 4.88 lsd stock rearend and a lightened steel flywheel with a sprung 4 puck brass button clutch and race pressure plate. Exhaust is RB road/race header into a straight 3" exhaust all the way back to a RB 3" stainless free flow muffler. Ignition is stock right now with MSD blaster coils but I am going to install two MSD 6al's soon. Got some bling coming from Australia and hopefull it will be here by this weekend too. I'll post some vid of the start up if all goes well. hehe. My next project will be a 12app so stay tuned. Here are a couple of pics.
Attached Thumbnails My bridgeport project.-bridgeport-007.jpg   My bridgeport project.-bridgeport-010.jpg   My bridgeport project.-bridgeport-015.jpg
Old Jan 8, 2008 | 07:01 PM
Latin270's Avatar
Looks awesome! Good job!
Old Jan 8, 2008 | 07:25 PM
876portturbo's Avatar
getcha brap on
Sounds like the car is going to be awesome, bridgeports are just wonderful
Old Jan 8, 2008 | 10:21 PM
Well, I am about a day away from firing the engine up. I have it installed. Just need to make brackets and mount my oil cooler and radiator and then she is ready to fire up. I will post vid of the start up so stay tuned.
Old Jan 9, 2008 | 09:16 PM
Well, I got it running tonight and so far so good. Engine sounds and runs very strong. Need to tune alittle bit. I am running a Weber 48Ida and my jetting is- main-240, air- 170, idle-65, venturi-42mm, and F11 emulsion with a 300 needle. Running MSD fuel pump at 4.5psi regulated of course. Any recommendations on jetting and tunning welcome as I am still pretty green with jetting. This jetting I am using is right out of RB catalogue. Here's a vid as promised.
http://www.youtube.com/watch?v=jQygbNzo114
Old Jan 9, 2008 | 09:45 PM
Latin270's Avatar
Wicked! Sounds sweet!
Old Jan 22, 2008 | 05:08 PM
MR2@20PSI's Avatar
Sounds good!
Old Jan 22, 2008 | 10:22 PM
Thanks. I am still breaking the motor in so I have been taking it easy, although a guy with a motorcycle was next to me at a light this last weekend and wanted to play. So we both got on it in second gear. I pulled hard on him up to about 8500 rpm's and then we had to stop at the next light. He was shaking his head and giving me thumbs up. hehe. So the butt dyno feels pretty good so far. Going to buy an A/F meter and I still have yet to install my LSD with 4.88 gears!
Old Jan 22, 2008 | 10:25 PM
Siraniko's Avatar
RX for fun
egt is what you need
Old Jan 22, 2008 | 10:41 PM
Wacky, both would be great, but I heard that egt's are a waste unless you are doing long circuit type racing as the sensors needs a long steady rpm based run to read correctly and do any good. Thus using it for street driving and 1/4 mile blasts would be useless. Like I said, this is just hear say, but from a pretty well known builder. Is this true?
Old Jan 22, 2008 | 10:46 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
EGTs are slow to respond but not a waste. If anything they're cheaper than wideband, and cheap enough to put one probe in each pipe so you can tell if one rotor is running hotter or colder. Very helpful for troubleshooting. BUT, only provide temp of exhaust fumes, not air fuel ratio which is what you're really after.
Wideband is much much much faster to respond and can be used to fine tune the whole powerband. Especially idle, progression, and accelerator circuits which is what you use the most on the street. Of course wideband works great at WOT as well.
Old Jan 22, 2008 | 11:09 PM
Thanks, that's what I searched out too. Wideband it is.
James Knox
Oct 22, 2015 05:08 PM
LongDuck
Oct 7, 2015 08:12 PM
