VDI system fix ? adjustment ? mod ?
Old May 27, 2001 | 07:23 PM
i went to the trackracers a link i found in the 250rwhp from an na post and for mods i seen people lsiting ..working VDI , wired VDI , VDI set at 5200 rpm ..etc .....how can i find out if my vdi system is working ...and if it isnt how can i make it work ..is there a how to for this like there is for the TB mod ? if not someone should make one ... anyone know where i can find this information ...im goin to be taking my intake manifold off soon so i figured i'd do it while its out ..thanx
1990 RX-7 GXL blaze red 5-Spd
Current Mods :
K&N drop in filter
Pacesetter header
High flow cat
RPO main pulley
A/F gauge
Fuel pressure gauge
TB mod
Future Mods :
Cat-Back exhaust
Act clutch
Kenne Bell boost-a-pump
Suspension Tech 1" drop
S-AFC , S-ITC
Contacts :
Wukillaa@aol.com
AIM - Wukillarmz
Old May 28, 2001 | 03:16 PM
c'mon guys ... i refuse to believe no one knows anything about the VDI system . help me out , im very interested in seeing if mine is working and if not i wanna get it to work . thanx
Old May 28, 2001 | 08:50 PM
Suparslinc's Avatar
It's Back!
VDI?
I think that variable dynamic intake, or the general name that Mazda gave to the intake system.
do a search on auxilary ports, or secondary ports, or 5th & 6th ports, just do some looking there is alot of information on it here although you will have to sort through alot of crap too. Joe
Old May 28, 2001 | 09:38 PM
SpeedRacer's Avatar
Formula Mazda Driver
The VDI stands Variable dynamic Intake. The VDI manifold is also called the upper intake manfifold. Its the manfifold that comes off the lower intake manifold. The VDI on it is the little actuator thingy with the vaccuum hose going to it. Air supplied from the airpump opens the VDI at 5600rpms to change the lenghth of the intake runners to optimize your air intake so you have a powerful low-end, as well as high-end. You can simply wire open the VDI so you don't have to worry about it not opening, but you will lose some low-end torque.
Jeremy
Black 1990 GTU
Mariah Headers
Bonez Racepipe
Bonez Intake(K&N Cone)
Volk Racing TE-37's 16x8's(shipping)
GC Coilvers
GC Camber/Caster plates
Eibach ERS Springs
Upgraded 4-piston calipers
SS Brake Lines
Hawk HP+ Pads
Brembo X-drilled Rear Rotors
Speedbleeders
AC Removed
P/S Steering removed
AIM - OnlyNDrms3268
Old May 28, 2001 | 11:14 PM
vaughnc's Avatar
knowledge junkie
After searching around, here's the Pics I found. Hope this helps:
Old Aug 22, 2001 | 01:57 PM
pd_day's Avatar
Spoolin'
What is that???
Th0m4s
Feb 26, 2019 02:04 AM
ncds_fc
Sep 10, 2015 03:52 AM
tsmith94FD
Aug 16, 2015 05:41 PM
rkhanso
Aug 13, 2015 11:40 AM
