upgraded turbo question
Old Apr 16, 2002 | 07:52 AM
Ryde _Or_Die's Avatar
Alright, can you guys look at this:
http://www.lourdsmusic.com/bnrsupercars/turbo8788.htm
And tell me which upgrade(if any) listed could get me in the 12s(preferably mid to low 12s)? Thanks alot.
Old Apr 17, 2002 | 12:08 AM
Jerk_Racer's Avatar
As simple as it may sound, e-mail BNR. I don't know what setup will get you to the 12s, but Bryan at BNR will get you on the right track.
jerk_racer@hotmail.com
Old May 16, 2002 | 01:16 AM
FEARED7's Avatar
Stage 2 went 12.3 at 114
Stage 2 TO4B went 12.3 at 114 on 18" radial tires with the stock N332 ECU! He has stepped up to a stage 3 and says he will be in the 11's soon!
Bryan
www.bnrsupercars.com
Old May 17, 2002 | 11:41 AM
SLOWT2's Avatar
From: new hampshire, middleton(a town so small we have no conveince stores)
go stage 3
Old May 17, 2002 | 09:03 PM
viperkiller7's Avatar
1.3 liters of whoop ass
I got a 12.6 at 116 on a to4b upgrade from majestic.. do they have a bigger up0grade now i was told this was the biggest last summer. 12.6 was with no boost controller or traction of course. i putting drag radials on and looking for a profec b if anyone has one.. looking for an 11
Old May 17, 2002 | 09:50 PM
ponykiller's Avatar
The stage 4 should be able to handle your needs....
Old May 17, 2002 | 10:18 PM
matt_ledbetter's Avatar
Re: Stage 2 went 12.3 at 114
Bryan
On the stock ecu? What else was he doing for fuel?
-Matt
Old May 21, 2002 | 02:01 AM
Jerk_Racer's Avatar
I got the stage2 but it's not on yet. It does look great for what it's worth.
Old May 23, 2002 | 01:49 AM
FEARED7's Avatar
Hey Matt. whats happenin?
The guy with the T2, his name is Will R. He has 720cc secondaries, Rising rate regulator, fuel pump, retarded the timing 6 degrees, ported engine 3mm Hurleys, ACT clutch, Super AFC piggy, NPR small FMIC, Bypass valve. I think that is about it!
later on!
Bryan
Old Sep 13, 2002 | 04:55 PM
Sorry to bring this back from the dead but I had to search(its been pounded in my head ).
Do you know what boost he was running bryan?
Old Sep 13, 2002 | 05:16 PM
Rpeck's Avatar
What R U thinking self?
I went with a stage 3 from BnR .. I will post times once the new motor is broken in.
Old Sep 13, 2002 | 05:25 PM
I contacted them but he doesn't want to upgrade S4 turbos anymore.
Old Sep 13, 2002 | 05:38 PM
Rpeck's Avatar
Doa, that sux, did he say why?
Old Sep 13, 2002 | 05:44 PM
Because of the amount of labor involved. He offered me a S5 turbo upgraded with the wastegate ported with an S5 manifold for like $1000 shipped but wasn't looking to spend that much money right now.
Old Sep 14, 2002 | 05:03 AM
slidingsky's Avatar
so on the stage 3, what kind of power would you expect to put down max? ANd whats the wastegate flange? Does he do something to the internal one?
Frisky Arab
13
Aug 18, 2015 05:30 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
