Windsheild sprayers
Old Apr 15, 2002 | 07:03 PM
.:Adam GS:.'s Avatar
Question Windsheild sprayers
Mine a clogged, and don't spray at all.. how do I take these thing off?
thanks
Old Apr 15, 2002 | 09:40 PM
SuperPhly's Avatar
take that middle thing out they are mounted to. also, try unclogging them with a pin (sowing pin) or somethign really small and sharp and pointy...
Old Apr 15, 2002 | 09:41 PM
Get a phillips,14mm box and open the hood. Take off the wipers first with the 14mm, then use the phillips to remove the 6(?) screws across by the latch. The center pipece pulls right up allowing you to get at the wiper motor and fluid lines. Hope that helps
Old Apr 15, 2002 | 09:56 PM
SuperPhly's Avatar
what's a 14mm box? is that a philips head screw driver? in fancy terms
Old Apr 15, 2002 | 10:02 PM
Redwood's Avatar
Find Racing
That would be a 14mm box wrench. Although a 14mm open-end wrench would work too.
Old Apr 15, 2002 | 11:53 PM
brownmound's Avatar
Anytime baby!
And while you are in there do your car and your favorite plant a favor and pull all of the composted leaves out of there and give them to your plant. Mines growing like crazy with that rotary powered mulch.
Right on.
Old Apr 16, 2002 | 01:52 AM
Felix Wankel's Avatar
Super Newbie
I think the wipers should take a 12mm, 14mm sounds too big. The cowl panel takes a phillps head. You need a crescent wrench or something (forget the exact size of it) to get the larger nut off the base of the wiper. I think you can get by by just taking the passenger side one off.
Old Apr 16, 2002 | 06:23 AM
ScruffyChimp's Avatar
The plastic that those little sprayers are made of can be very brittle by now. I just broke mine this week. What a PITA.
Once you have the cowl plate off you need to undo the metal clip on the back, and remove the fluid hose. It's pretty simple.
Bye,
ScruffyChimp
Old Apr 16, 2002 | 08:18 AM
jeremy's Avatar
male stripper
no no no, first remove your driver's front wheel. then prop the driver's door on a stand. make sure your wipers are in the upright position, and turn them on. now try to get the screws in the plate out with a narrow flathead screwdriver. once you have given up break the sprayer off, go to the junkyard and buy one that looks like you want. pop into hole and hookup line or hook up line through hole then shove sprayer in hole. this is all best done with your and my pal, mr jim beam.
if none of this works you'll need a new ecu.
Old Apr 16, 2002 | 11:20 AM
Directfreak's Avatar
I am a Jeeper Now.
Yeah, a Haltech would be best.
Old Apr 16, 2002 | 03:08 PM
85RX7GS's Avatar
When I first bought my car, I tried the washer (after I just filled it up, ofcourse) and I just heard the pump running. So I drove forward and noticed a big puddle in the mirror. Anyway, due to a lack of hoses, I had to replace all those that were under the grill. It's easy to remove, just pop the hood and take out some bolts.
Old Apr 16, 2002 | 03:11 PM
Pele's Avatar
Right near Malloy
Two words... Compressed air.
Blow down the nozzles, then try spraying them.
Old Apr 16, 2002 | 03:13 PM
if your nozzles are broken, you cna get those lighted ones for cheap and have new nozzles at the same time.
Old Apr 16, 2002 | 03:24 PM
nimrodTT's Avatar
all aboard!
Just dont turn the lights on.
Old Apr 16, 2002 | 06:22 PM
82transam's Avatar
Never Follow
Those lighted ones are sweet, I'm putting them on my rex when I get the time. I guess some of you will say thats "ricey" but I don't care.
Old Apr 16, 2002 | 10:53 PM
jimtesla's Avatar
lighted sprayers
Hey
Mine did not work and I got a set with that was dark with red lights........hooked it up to the parking lights
works great......color matches the dash of my 84.......
By day nobody can tell.......looks stock..........
also replaced the tubing.....just broke off in my hands.........
Old Apr 17, 2002 | 06:47 AM
I've never heard of these lighted ones.
Does anyone have a link to a picture of one?
Thanks,
ScruffyChimp
Old Apr 17, 2002 | 08:06 AM
jeremy's Avatar
male stripper
just fly in to murray. there is a riced maxima a few apartments down with some hip black light ones. he's hella fat yo.
Old Apr 17, 2002 | 10:09 AM
They look nice and those big ol' suv's can see you better. Any of the auto zone or pep boys have them. Around $20 if not less.
Old Apr 17, 2002 | 01:02 PM
or you could always just use a spray bottle behind the seat. Kidding...
Old Apr 17, 2002 | 03:05 PM
etherhuffer's Avatar
Soak the nozzle in vinegar overnight. Scale in the holes will dissovle out. Run the pump with the nozzle off to flush the lines and water the neighbors yard.
Old Apr 17, 2002 | 03:17 PM
For the people with rear washer,
Run the line down to the tires and fill it up with bleach. Spray and presto! Pure white smoke cloud when you do a big burnout Use to do this back in the day. man, I'm getting old
theorie
86
Oct 21, 2004 06:01 PM
Liquid Anarchy
Mar 3, 2004 04:04 PM
nataku
Jun 4, 2003 07:59 PM
Roy James
15
Feb 11, 2003 07:36 AM
newRX7fan
Dec 9, 2001 05:33 PM
