12A 6mm Rotor at dealership
i went to pick up my t-stat that i ordered the other day from the dealership and i when i walked in i see a rotor housing and there was a rotor sitting in the housing pointed up so i pull the rotor out to look at it and show my daughter. well what i noticed when i was lookin at it was the apex grooves where 6mm brand new rotor and housing i mean the housing was mint on the inside super shiney! Also on top of the housing there was what appeared to be a water temp sensor dead center on top in the middle of it. im guessing that this was for an old shool like Rx3 2 dizzy 12A(correct me if im wrong) i thought it was pretty cool that they had that there concidering they share the palce with suzuki well they used rotarys on there old bikes, either way it was cool! i ll see if i can get a few pics of it.
Yeah, 16X has a fuel injector the top of the housing with the electrical contacts facing the driver's side. I think it was green in the demos that are out there. If it WAS a 16X, go back and get some pics, man. The rotor is physically bigger and runs on an e-shaft with more eccentricity. Lots of changes.
i just got back from the dealer and i was asking him about the housing and he was telling me that it was from one of his techs that he had from back in the day and he gave it to them. and the 12A stamp isnt where the are now just above the spark plugs its higher on the housing.
i also talked to him about 16C display, he said that they are working on it and they should have one around spring time. i got some pics but i have to get them from my fone, so hold tight.
ok so here are the pics from my fone.
notice how the rotor has 2 spots for side seals and see the plug on the top of the housing its alil wierd i dont think that its a water temp thingy anymore but it does protude into where the tension bolts go.
Trending Topics
I've got one of those rotors in a 12a housing in my office at work with the double side seals. Makes it a little easier to explain to all the truck drivers that stop in my office.
Nice to learn what it originally came out of.
that looks like frankies desk? ralph had a new 10a rotor in the display case for years...
It is near the front cover. The lifting hook is traditionally placed on the front rotor housing. The rear housing had a decent looking #3 phillips screw with 8mm x 1.25 thread. They were otherwise interchangeable.
I recently posted some pics of a twin dizzy 12A I was going to use in a baja. I decided to go with a 13B instead so the aluminum adaptor is up for grabs. Anyway here is the thread with pictures. https://www.rx7club.com/forum/showpo...6&postcount=40
Nice find! Never knew about the dual side seals.
Not trying to thread jack, but what transmission are you going to use? I assume a FR Layout?
Edit: Only asking because I heard VW bug transmissions were weak for higher RPMS.
its from an rx3.......i had the same motor in my FB.......the apex seals that go into the rotor are carbon....sofor that reason the housings can never really go bad....the only that can happen is that the seals go bad which they do in average 60,000-70,000 kms
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
