Engines and Posi's
Old Apr 15, 2002 | 01:14 PM
Engines and Posi's
I was just wondering wherew i could get information and maybe compare the diffrences between my stock 1988 13b engine and a tri rotor twin turbo j-spec engine, and where i could get it. I alo would like to get rid of my limited slip dif where could i find a posi trac diff for around 5 bills
Old Apr 15, 2002 | 01:30 PM
peejay's Avatar
Old [Sch|F]ool
you're kidding right?
posi is just chevy's name for limited slip...
Old Apr 15, 2002 | 02:04 PM
Icemark's Avatar
I was thinking the same thing. Isn't a posi trac rear end exactly the same as the clutch type LSD found in some of the series 4 cars?
Old Apr 15, 2002 | 05:26 PM
Turblown's Avatar
Turn up the boost
What? really.... Um, i though posi both wheels spin no matter what, and heard it sucks around corners. chirpin...
Rotary Performance Parts
Old Apr 15, 2002 | 05:29 PM
I wish I was driving!
Posi is not a fully locked rearend, which squeals around corners and is HORRIBLle on tires and axels. There are plenty of different types of differentials, but posi-traction is just chevy's name for a clutch-type LSD.
Sean
Old Apr 15, 2002 | 05:45 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Engines and Posi's
Take a deep breath and visit the 20B Forum.
Old Apr 15, 2002 | 05:48 PM
peejay's Avatar
Old [Sch|F]ool
You're thinking of a spool, which is not a differential at all, it's just something that the ring gear bolts to and the axles slide into. No differential action whatsoever.
There's also the welded diff AKA "Lincoln Locker" (named after Lincoln-brand welders) which is the same basic thing except not as strong. The gears in an open diff are welded together for the same effect as a spool.
Microtech
30
Apr 23, 2016 06:37 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
