How many FD owners run a staggered wheel setup?
Old Apr 15, 2002 | 09:51 AM
DomFD3S's Avatar
Mod Powers...gone!
Pretty easy.
How many FD owners run a staggered wheel setup versus a non-staggered wheel setup?
Old Apr 15, 2002 | 10:45 AM
phatmonky's Avatar
William
https://www.rx7club.com/forum/forumd...?s=&forumid=20
Old Apr 15, 2002 | 10:50 AM
ttpowerd's Avatar
HARRRRRRRRR
Most ppl with aftermarket wheels do bc the front does not hold a large tire whereas the back can hold a larger wheel/tire.
Old Apr 15, 2002 | 11:00 AM
SleepR1's Avatar
I do for the track...245/45-17 on 8.5 x 17 and 275/40-17 on 9.5 x 17...tires are Hoosier R3S03, wheels are SSR Competitions...
There is a slight amount of understeer with a staggered setup, and I can't steer the car's rear end as well with this setup, but the upshot is if you overcook a turn-in, just ease of the gas, the nose points in very nicely...
Much easier to steer the rear end with 255/40-17s all the way around, which is what I have for my public road, autocross, and wet track setup (9 x 17 SSR Integral A2s, with Yokohama AVS Intermediates)...the downside is if you overcook a turn-in, you must have fast reflexes to catch the car's rear end, and feather the throttle...(which is loads of fun!)
Old Apr 15, 2002 | 11:13 AM
DomFD3S's Avatar
Mod Powers...gone!
Actually, I posted in the 3rd gen area because I only wanted 3rd gen owners to reply. I do realize that there is a wheels area though. Thank you for pointing that out.
Old Apr 15, 2002 | 11:22 AM
purepsi's Avatar
i ran a 17x8 with a 235/40-17 in the front and a 18x9.5 with a 265/35-18 in the rear. enkei rpo1 with nitto rubbers
Old Apr 15, 2002 | 11:33 AM
solo1seven's Avatar
Hi,
I'm running 235 45 17 A032R's up front and 255 40 17 A032R's in the rear on Simmons 17*8, and 17*9 wheels. I find the car has a neutral feel on the track and behaves very well. I am quite happy with this set up.
Andrew Wojteczko
93 RX7 R1
87 944 Turbo
Old Apr 15, 2002 | 12:35 PM
GsrSol's Avatar
Z06 powered FD
I have 17x9 and 17x10 with 245/40/17 and 275/40/17
Old Apr 15, 2002 | 12:50 PM
R Xplicit's Avatar
i now have 18x8.5 w/255-35's up front
and 18x9.5 w/285-35's in the rear...
i changed from an 18x9 and 19x10 set-up
Old Apr 15, 2002 | 12:56 PM
JspecFD's Avatar
Originally posted by solo1seven
Hi,
Where'd you find the 235/45 sizing A032R's? I could only find the 235/40 sizing and ended up going over to S03's since I could get the 235/45 and 255/40 f/r tire sizes.
Old Apr 15, 2002 | 02:11 PM
solo1seven's Avatar
I purchased these at the end of the 2001 season from a company in mississauga ontario Canada.
Andrew Wojteczko
Old Apr 15, 2002 | 02:21 PM
jpandes's Avatar
Do you have a picture of your car with your wheels??? I am thinking of doing this too? 17"s x 18"s
Old Apr 15, 2002 | 08:36 PM
MILD7's Avatar
running 18x10 on 265/3518 and 18x8 on 225/4018.
Old Apr 16, 2002 | 12:01 AM
racer rx's Avatar
I run with 235/40/17's front"Dunlop Sp8000
rear: 255/40/17 Nitto 555's
And at the Drags: 305/40/16's M and H racemasters....
LUV the 6500 - 7000 rpm launch. WHAT A RUSH!!!
jc.
ChrisRX8PR
Aug 21, 2015 01:56 PM
Wolf_
Aug 11, 2015 04:23 PM
