When I install my header.........
Old Apr 15, 2002 | 03:56 AM
FC3AZ's Avatar
Do I need to worry about heat effecting the ECU in the stock location?
Old Apr 15, 2002 | 08:30 AM
assassin's Avatar
Na, there will be no such worries needed. Maybe the only problem is the o2 sensor wire might touch the header and become burnt. Make sure the O2 wire is tucked away. Other than that make sure you open your 5/6 ports as soon as you put that header on with that high flow cat and exhaust. If not your actually going to run slower than stock due to lack in backpressure.
Old Apr 15, 2002 | 11:45 AM
FC3AZ's Avatar
thanks for the help assassin.......
Old Apr 15, 2002 | 12:24 PM
MaxRX7's Avatar
hambre y sueño
worry free
24seven_dada
20
Nov 10, 2018 12:03 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
astrum
Sep 7, 2015 11:41 PM
Enzo1944
Sep 6, 2015 08:57 AM
