which one>?<
Old Dec 6, 2007 | 09:00 AM
FB_drifter_X's Avatar
9000 rpm's of sexy
which one>?<
which swap would be easier..a 13bT or a 13bREW? i personally would like the rew but how hard or expensive would this swap be?
Old Dec 6, 2007 | 12:48 PM
djessence's Avatar
djessence
13Bt is definetly the more common swap. Fair amount easier and there have been alot of people who have done it and can share their knowledge about what to do/not to do.
The 13B REW has been done a few times but it is much more difficult and to do it right will cost you at least 10g
https://www.rx7club.com/showthread.p...hlight=13B+REW
there are a couple other threads. search 13B REW in the 1st gen section and itll bring up a bunch of info. similarily 13B tII swap, there is a ton of info on those ones.
Old Dec 6, 2007 | 05:14 PM
9000 rpm's of sexy
yea i def do not have 10k to drop in any vehicle right now so t2 is my best bet... How hard would it be to get 350-400 reliable horses out of it though i know that will be expensive but later on down the road also
Old Dec 6, 2007 | 06:07 PM
85 FB's Avatar
7-less
Rotaryshack has a car with, IIRC, 680 RWHP. I think that's his username, too, but I can't remember that well.
You'd be surprised how easy it is to get some massive power out of these things. Besides Rotaryshack, member Directfreak has a car you should check out on via his YouTube links. Do some searching, you'll be amazed.
Old Dec 6, 2007 | 06:21 PM
85rotarypower's Avatar
love the braaaap
Getting 350-400hp on a TII will take about 5 grand on top of the cost for the base engine swap, mabey more. That would require a bigger turbo, FMIC, much bigger injectors, stand alone ECU, possible streetporting... The list goes on. I remember reading once that to get to 500hp and have it track and road worthy (safe and legal), it took directfreak 20 grand.
As far as rotaryshack, it USED to be a 680hp 12A. Last I saw it was up to 720hp.
Old Dec 6, 2007 | 06:45 PM
djessence's Avatar
djessence
If you have some spare time try a bunch of different searchs about t2 power and swaps and what not. There is a TON of useful information about various peoples swaps, and how to get power and how much it cost etc etc. Just takes a bit to find the threads that help a bunch.
Directfreak is definetly good to check out but he has put quite a bit of money into his project.
As well once you start getting above 250-300 HP you need to start doing other conversions, such as rear end, big brake kit is definetly recommended, and suspension. Are you planning on a drag car or a track car. Give us some more info about what you would like to do and which car you are going to put it in and you will get more answers
On the searching side again there are a couple useful Project thread with pictures and processes in them
Good hunting
Old Dec 6, 2007 | 07:30 PM
Skidtron's Avatar
Being poor sucks!
The FC engines are too easy to swap do the REW. Which is not that hard either. So your 12A pooped finally after drifting a buch huh? That's how mine died to. The coolant o-ring failed. I opted for the S5 NA engine in mine working on it still. Waiting for parts actually. I'll let you know hoe it slides went it's done if your into drifting
Old Dec 6, 2007 | 10:05 PM
trochoid's Avatar
Old Fart Young at Heart
If you want to know about FC hp, search the 2nd gen section.
Old Dec 6, 2007 | 11:53 PM
9000 rpm's of sexy
i want my fb to be a daily driver and dont want anymore than 400 out of it. i willl be drifting a little bit, not all the time but a little bit. i live in the mountains so i have some great spots to drift and some monster parking lots...I would love to see some drifting vids skidtron...
Old Dec 7, 2007 | 12:34 PM
9000 rpm's of sexy
ok i have a noob question i think... what exactly is bridge porting???
Old Dec 7, 2007 | 12:43 PM
djessence's Avatar
djessence
this has been covered quite a bit. Do a bit of searching
As well, go over to www.nopistons.com, check out their info. They have quite a bit on porting in the engine building section more how to. And a bunch of info in a couple other sections. Just take a look around
Old Dec 7, 2007 | 12:54 PM
djessence's Avatar
djessence
this thread will help your understanding a bit
https://www.rx7club.com/showthread.p...rt+bridge+port
Old Dec 7, 2007 | 12:55 PM
djessence's Avatar
djessence
http://fc3spro.com/TECH/PORT/porting.html
Old Dec 10, 2007 | 09:41 AM
9000 rpm's of sexy
oh thanx alot for that djessence that really helped my friend said that bridgeporting makes it sound like it has cams...
Old Dec 10, 2007 | 02:55 PM
djessence's Avatar
djessence
haha imo it makes the car sound like a massive weed wacker
Old Dec 12, 2007 | 09:10 AM
9000 rpm's of sexy
his third gen isnt bridge ported and it sounds like a massive weed eater but he did make the exhaust port bigger and he has a four inch turbo back exhaust but that car absolutely screams when he gags it
