Steering column information needed.
Old Dec 5, 2007 | 01:41 AM
jaylee000's Avatar
are 1st gen 7 steering wheel column the same as 2nd gen steering wheel column
thank for the help cause i didnt see anything in the faq or a search
Old Dec 5, 2007 | 02:00 AM
kenn_chan's Avatar
Savanna Rx-7
No,
not even remotely close, the 1st gen (SA/FB) uses a recirculating ball steering gear box, and the shaft goes directly into the gear box. the gear box must be removed in its entirety at the same time as the column in order to remove the column.
the 2nd gen(FC3S/FC3C) have rack and pinion steering, you have a universal joint inline the column and the steering geara box can be removed seperately from each other.
if you cannot visulise the differenance between them after this explanation, I would reccomend that you should look into a couple of FSM's to get a better idea.
kenn
Old Dec 5, 2007 | 12:13 PM
jaylee000's Avatar
i want to put a momo steering wheel but am having trouble in finding a hub but find plenty for the 2nd gen 7s can i use a 2nd gen hub on my 1st gen
Old Dec 5, 2007 | 12:37 PM
85 FB's Avatar
7-less
This link may help.
https://www.rx7club.com/1st-generation-specific-1979-1985-18/aftermarket-steering-wheels-683357/
Old Dec 5, 2007 | 02:39 PM
Bptznumba1playa06@sbcglobal.ne's Avatar
Who wants to be pisst' on
get a universal hub they fit all cars my wheel came with the hub and my wheel came off a 3rd gen.
