which radiator to use for my 87T2??
Old Apr 14, 2002 | 05:32 PM
duehuynh's Avatar
so this morning, i saw some coolant between the radiator's plastic and aluminum interface. Oh well, it's been 2 months since she sucked $$ out of my wallet..
checking Mazdatrix, I noted the following replacement radiator for sell:
86-88
2-row Metal M/T & A/T 867-RAD $267
2-row Plastic/Alum. M/T 15-200D-N326 $400
89-92
2-row Metal M/T & A/T 2006-RAD $233
2-row Plastic/Alum. M/T 15-2000-N350 $306
* any performance difference between the plastic and metal version?
* is the metal version drop-in replacement (I am not interested in the Fluidyne because it is not a drop-in fit)?
* can anyone tell me why the 89-92 radiators are cheaper? can I use the newer radiator? (currently my radiator has the pressure cap and overflow on the top of the radiator).
thanks for your feedback.
dewey
Old Apr 14, 2002 | 06:16 PM
RETed's Avatar
http://www.absoluteradiator.com/
$430 for a Fluidyne UPGRADE radiator
-Ted
Old Apr 14, 2002 | 06:24 PM
fc3s.org's Avatar
OG
Ted beat me to it The Fluidyne is a nice unit. I have one in my 91 vert and it is really nice. I have pics and an install write-up on my site under How-To's then under engine if you are interested.
Old Apr 14, 2002 | 06:29 PM
duehuynh's Avatar
ah hah! but...
Before I posted the question, I did some searches. Saw several recommendations for the Fluidyne radiators (including ted's old posts).
But...
also noted several conflicting notes. Some stated that this is not a drop-in replacement. Could you or anyone address this issue?
In specific -
1) the Fluidyne use 14psi cap, stock is 12psi. any issues?
2) the Fluidyne does not have bleeder hole...so how would one purge the system of air?
3) do the Fluidine mounting holes line up with stock mounting locations?
4) what about upper/lower rad hoses? is it compatible with stock hoses? (different hoses for diff year - which new one should I be getting?)
4) does it have outlet for the overflow tank hose?
5) would I be able to reinstall stock fan shroud/air box/etc????
I do not mind spending the money for quality product. However, I do want the fit to be as close to stock as possible.
thanks for the input
dewey
ted: oh...what's your progress on the FMIC kit?
Old Apr 14, 2002 | 06:30 PM
RETed's Avatar
Re: ah hah! but...
Non-existant at this time - everything is on hold until we secure a shop space.&nbsp Our realtor is dicking with us right now...
-Ted
Old Apr 14, 2002 | 06:31 PM
duehuynh's Avatar
for dave
nice write up...nice site!
could you expand on my ??? above?
thanks again!
dewey
Old Apr 14, 2002 | 06:32 PM
fc3s.org's Avatar
OG
Re: ah hah! but...
But...
In specific -
dewey
Go to my site and read the write-up and all of your answers are there. It is a bolt in replacement.
Old Apr 14, 2002 | 07:29 PM
duehuynh's Avatar
dave - stupid ?? but
what is a "barb fitting"???? and where do you get this? McMaster Carr??
thanks,
dewey
Old Apr 14, 2002 | 08:13 PM
fc3s.org's Avatar
OG
I got it at the local auto parts store. It is 3/8 NPT thread in 1/4" size (if my memory serves me correctly.
Also I would recommend using the stock pressure cap, as the 16lbs one that came with the radiator made my water pump leak through the weep hole, hence I got to do a water pump replacement write-up
Overall this radiator is one of the best out there for bolt in replacement, and it is priced well for the quality you get. www.mazdaformance.com carries them as well, and that is where I got mine since I have dealt with Brian from there alot and they are very good.
Old Apr 15, 2002 | 07:56 AM
Ryde _Or_Die's Avatar
-Ted
Fluidyne- $415 saved you $15, lol.
Old Apr 15, 2002 | 10:11 AM
RETed's Avatar
You mean Fluidyne is selling direct now?
-Ted
Old Apr 15, 2002 | 10:15 AM
-Ted
No my dumbass forgot the link, lol:
http:///fluidalradfo1.html
Old Apr 15, 2002 | 10:19 AM
RETed's Avatar
Try again...that URL doesn't work.
-Ted
Old Apr 15, 2002 | 10:23 AM
ponykiller's Avatar
summitracing.com
The universal Howe radiator, 19inX22inX3in. Only $200, but you will have to fabricate a mounting location and probably go with an electric fan. That is what I am using and it works great, plus it has metal endtanks not plastic.
Kris
Old Apr 15, 2002 | 10:24 AM
Damnit!
http:///alrad.html
Old Apr 15, 2002 | 10:25 AM
WTF!?! Thats not what I typed. Here:
www. /alrad.html
Old Apr 15, 2002 | 10:26 AM
Ok this forum doesn't like what I want to type.
http:// www. /alrad.html
Old Apr 15, 2002 | 10:27 AM
**** it. Go to .com and then go to cooling and then to fluidyne radiators. Don't know why but it won't post the link I keep putting in. Think it doesn't allow for the other sites link on here.
rotor motor sports . com
There are no spaces in there but it won't let me do it without them.
MidnightOwl
Sep 25, 2015 10:24 PM
