Single turbo no intercooler questions
Old Dec 3, 2007 | 09:43 PM
Christopher W.'s Avatar
I am trying to find info on people running single turbo no intercooler. I can't find anything in the search engine so I gotta ask. Can someone point to some threads already on the subject or can we talk now. I am going to run a 13B RE Cosmo, streetport and built. I am interested in how much boost an horsepower is possible with no intercooler. Looking at GT35R with Electomotive TEC3R. I just don't want to hack up the front of my car with an intercooler and I want as little lag as possible. I might consider water injection if I have to.
Old Dec 3, 2007 | 09:49 PM
t04tii's Avatar
GhostSS
https://www.rx7club.com/auxiliary-injection-173/running-non-intercooled-option-685701/page3/
Old Dec 3, 2007 | 09:52 PM
Cheers mate!
Old Dec 4, 2007 | 12:58 AM
cozmo kraemer's Avatar
Darkside FD
If you have any questions let me know
Old Dec 4, 2007 | 12:04 PM
Viking War Hammer's Avatar
*** Bless The USA
I'm not running a intercooler
Old Dec 4, 2007 | 02:04 PM
turBRO240's Avatar
Certified Rotorhead
I was reading cozmos thread and holy ****... he gets intake temps of 50C... even with water/meth
Even under constant boost my intake temps have never went above 20C on a 80F day. (im running FMIC)
Old Dec 4, 2007 | 02:47 PM
AMRX7's Avatar
Where and how are you measuring your intake temps. Are you really saying that under boost your intake temps are lower than the ambient air? That seems rather impossible without some other source of cooling.
-Andy M.
Old Dec 4, 2007 | 02:48 PM
classicauto's Avatar
Crash Auto?Fix Auto.
-Andy M.
+1
Tracking a friends FD......GT35R, large SMIC....runing 10-12 pounds I was seeing 52-53C according to the PFC.
Less then half that seems impossible without chemical cooling of some type.......
Old Dec 4, 2007 | 02:51 PM
rotarygod's Avatar
Rotors still spinning
^ You are saying that with nothing more than air/air intercooling, that on an 80* F day, you only got 71.6*F (20*C) intake temperatures? That's impossible. You can't get lower than ambient with air/air intercooling alone.
Old Dec 4, 2007 | 02:53 PM
RacerXtreme7's Avatar
NASA geek
Yeah, 20*C = 68*F. No way in hell are you going to get below ambient (80*F) with just a front mount.
~Mike........
Originally Posted by rotarygod
Wow everyone called that out at the same time.
hehe
Old Dec 4, 2007 | 02:54 PM
*** Bless The USA
I saw that when he first posted, I knew it was only a matter of time before someone to tear him apart
rotarygod's Avatar
Old Dec 4, 2007 | 03:02 PM
rotarygod's Avatar
Originally Posted by classicauto
hehe
How did you quote me BEFORE I posted??? Weird!
Old Dec 4, 2007 | 03:05 PM
*** Bless The USA
I know, I saw your post then replied but it somehow put my post before yours ?
The forum had a misfire.
Old Dec 4, 2007 | 03:16 PM
ditto, i read, quoted, and then had my mind boggled
Old Dec 4, 2007 | 07:59 PM
turBRO240's Avatar
Certified Rotorhead
Ill try to get the log for you guys.
My intake temp sensor is located 1 foot after the intercooler
I was around 70mph+ the whole time.
Old Dec 4, 2007 | 09:23 PM
Darkside FD
45-50C with water is where you want to be...I am trying to tune things so I am right around there at all times. Maybe slightly below.
With the water/alcohol (50/50) and at a ratio of 15% injectant to fuel, I was very much below ambient to the tune of 25C intake temps when it was nearly 40C outside. I am trying to stray away from this dramatic change and make the system react to keep intake temps the same (as much as possible) at all times. I have proven that i can cool the air down below ambient.
The joy of my setup is that my intake temps are the same whether my car has been sitting at idle for an hour, or cruising at 70mph, I have ZERO heat soak. With the temps out here now in the mid 70s (F) during the day, I have 38-42C intake temps in vacuum and low boost. Under full boost (currently 15psi) with 100% water I am right around 45C...
Which is where I want the temps to be...with the water injection and how cool my engine runs (oil and coolant temps) I am not in the slightest worried about detonation from running too hot an intake temp.
Besides....looking at how the water injection COOLS the air is looking at only a small part of its total benefit to the engine. Water controls the flame front in the combustion chamber and this suppresses preignition. This allows the use of increased timing and much leaner AFR. That is the HUGE benefit. You can have much hotter IAT without seeing detonation. Having the consistency of intake temp, helps with the consistency of my tune.
Old Dec 4, 2007 | 09:37 PM
Darkside FD
I will have logs of a 20 minute track session that I will post come the middle of January (track session is the first week of Jan). I will have logs from the dyno here in the next couple of weeks. Have to coordinate a lot people to be there for the dyno runs and that is delaying things slightly.
Old Dec 4, 2007 | 11:44 PM
rotarygod's Avatar
I understand you may be seeing those readings but that result isn't physically possible. You've got a sensor calibration issue. Something isn't accurate. Unless you too are running some form of alcohol/water injection, or an air to water intercooler with an ice tank, you can not get cooler air temps post turbo than ambient outside air. This is not possible with an air to air intercooler unless you are spraying it down with something very cold. If you are getting a colder reading, something is wrong with a sensor, gauge, or calibration somewhere. I'd check into that.
Old Dec 4, 2007 | 11:51 PM
turBRO240's Avatar
Certified Rotorhead
Figured.
Old Dec 5, 2007 | 09:54 AM
dubulup's Avatar
development
I want pictures! of intake and plumping to elbow...very cool
Old Dec 5, 2007 | 12:46 PM
turBRO240's Avatar
Certified Rotorhead
+1 for lots of underhood pics
Old Dec 9, 2007 | 03:05 PM
Darkside FD
Here you go
https://www.rx7club.com/showpost.php...&postcount=158
Old Jun 10, 2009 | 11:54 AM
*** Bless The USA
i had bad results with this, no intercooler and two M14 nozzles spraying methanol......... my intake temps never dropped below 220 f
