EFans..Suggestions,anyone?
Old Nov 27, 2007 | 12:22 AM
misterstyx69's Avatar
Retired Moderator, RIP
I am changing over to Electric.My problem is which Efan to use..Of course,I am a Busted-*** Cheapo!..I have found this one on Summit.Has anyone used this? http://store.summitracing.com/partde...5&autoview=sku This would be going on an N/A.and hopefully If I go to TII,I am hoping that the Cooling System Upgrade will Suffice for Both Sides of the Fence(N/A or TII).any Suggestions guys?.Thanks,STYX.
Old Nov 27, 2007 | 06:56 AM
certifiednut's Avatar
Mike Honcho
here are a few i havnt used either of them, but i have seen others on here using them with no problems
1)http://www.sherco-auto.com/fan.htm
2)http://store.summitracing.com/partde...5&autoview=sku
Old Nov 27, 2007 | 09:19 AM
Aaron Cake's Avatar
Engine, Not Motor
This has been covered so many times...
If you want cheap, you can't go wrong with the GM fans as described here:
http://www.aaroncake.net/rx-7/efaninstall.htm
Very cheap from the wreckers and highly reliable as it's a OEM product. Also fits the 2nd gen rad perfectly.
Old Nov 27, 2007 | 06:55 PM
turbine's Avatar
why is everyone so damn cheap. black magic all the way
Old Nov 27, 2007 | 07:22 PM
phoenix7's Avatar
Fiero GT E-fan. ~2100CFM and 16 bux from the junkyard.
Old Nov 27, 2007 | 07:23 PM
hungery4rice's Avatar
NYTSTLKR
I ran the zirgo fan for a while with a koyo and it would take a while for the temps to come down after hard driving. You will need a fan shroud(sp??) if you go with it. just get a better radiator and that should do it.
Old Nov 27, 2007 | 07:31 PM
Thanks for the Usefull info AARON,Certifiednut...And Turbine,,I am Cheap because I am Retired(also Disabled),so I can't go Out and Make Big bucks to buy Big Buck Stuff like Haltechs and Turbos!.I am stuck in N/A land with my 150 HP!.Soon to be 151..haha!..Black Magic?..a little UP there in price..so thanks,But Unfortunately,No Can do.
Old Nov 27, 2007 | 07:32 PM
Soma's Avatar
I knw wht u did last sumr
What's up misterstyx69?
Have you checked out Perma-Cool? Not too much more expensive.
They fit together nicely with the Taurus shroud's.
I'm running the 16" with the larger Taurus shroud and
a friend of mine has the smaller Taurus shroud and
is running the 14". Both work well.
For about $60, you could probably get both the Taurus shroud and fan from a junkyard but I bet that fan draws a few more amps. Have fun!
Old Nov 27, 2007 | 07:52 PM
coxxoc's Avatar
Shooting for 500
The efan for the Taurus with a 3.8 liter fan works great with my setup. This fan is larger than the one that is for the 3.0 liter Taurus. I'm running a Koyo radiator and the shroud fits great. It cools quickly any time it is activated. I used only the low speed of the fan all summer and it always dropped the temp when it turns on.
There is concern that the fan pulls too many amps by some other club members. I've not had any problems with this fan (no immediate voltage drop, or dimming of lights, etc. I'm running a remanned S4 alternator. I do not, however, use any radio equipment or air conditioning.
Oh yeah, it cost me $40 at the local junk yard.
Josh
Old Nov 27, 2007 | 07:59 PM
glh-fc's Avatar
^^^^2nd the ford efan.it's cheap,they are easy to find and work pretty good.
Old Nov 28, 2007 | 05:54 AM
RotaMan99's Avatar
Leme do a search for you...... this is one thread amongst MANY others.
https://www.rx7club.com/showthread.p...t=electric+fan
Old Nov 28, 2007 | 06:13 AM
KNONFS's Avatar
B O R I C U A
I've used the black magic flex a lite fan for over 15 years now (it finally died, las summer).
The SAME fan can be found at:
Its a couple of bucks cheaper...
Old Nov 28, 2007 | 10:34 AM
slo's Avatar
slo
registered user
My black magic lasted a month before the motor died
Old Nov 29, 2007 | 03:33 AM
sharingan 19's Avatar
Rotary Revolutionary
...maybe it shouldn't have been wired to be on constantly....
Old Nov 29, 2007 | 03:41 AM
phoenix7's Avatar
kills your alt too. I have mine wired to a thermoswitch. No power drain, and no issues with cooling.
Old Nov 29, 2007 | 06:36 AM
KNONFS's Avatar
B O R I C U A
Did you called them? Flex a lite (and pro form) have an exceptional warranty. I'll admit to their WEAK thermoswitch, other than that they have been great. I've installed two black magics, and a pro form (on different cars); none of them had an issue (except for mine that lasted over 15 years).
BTW - Mine was configured to ON at all times for several years (stupid thermoswitch stopped working).
