ive heard of hazards of doing this but what are they
Old Nov 26, 2007 | 10:12 PM
yudaya's Avatar
ive heard that its not a good idea to wire open yours 5th adn 6th ports, but why is it bad?
Old Nov 26, 2007 | 10:15 PM
Fumi's Avatar
Addicted to the PNW
you lose power at lower rpms its better to leave them alone if they work and repair them if they dont
Old Nov 26, 2007 | 10:32 PM
yudaya's Avatar
but i dont have the air pump,and this motor is going to just be a beater for now
Old Nov 26, 2007 | 10:47 PM
Delphince's Avatar
Rider of the Sky
It won't break your motor if that's what your worried about, and they'll still work (though perhaps not right on cue) if your air pipe is still connected to your cat, since the ports work on the adjusted sum of their two pressures. If nothing is still connected, wiring them open will just trade off low end for high end. All they do is adjust the available paths for air entering the motor.
TitosToy's Avatar
very sleepy!!
what year is your car? not having the aux ports doesnt really hurt the engine. as fumihiko explained - you'll lose low-end power and you'll hurt gas mileage (hope that doesnt scare you ), if it's a S4 you dont have to worry about the airpump controlling the aux ports. but all in all it should be fine as a dd. mine hasnt been a bother to me.
Old Nov 26, 2007 | 11:51 PM
TurboMazdaSpeed's Avatar
1.3L piston eater
on my old NA i had wired open 5th and 6th ports.... it sucked **** for driving! and it was horrible on gas because you would have to give er if you wanted to go anywhere lol .. especially on hills
Old Nov 27, 2007 | 12:14 AM
arghx's Avatar
rotorhead
6 ports wired open is annoying for daily driving but I noticed it more because I was street ported, which already hurts low end.
On the other hand, I tried the 12v pump mod for the ports and it just wasn't reliable over the long haul. **** always went wrong with it. Carbon would build up in the auxilary ports sometimes, my relay would break, I just got sick of it and wired them open again.
Old Dec 2, 2007 | 09:22 PM
yudaya's Avatar
its gunna be a weekender and when i dont have gas in the other car.... my car is a s4 87na SE
Old Dec 3, 2007 | 09:53 AM
Roen's Avatar
The Silent but Deadly Mod
If you have an S5, the air pump is needed for 6PI activation. Sicne you don't have that, you might as well wire them open.
If you have an S4, read the posts above.
Old Dec 3, 2007 | 10:06 AM
noobzilla's Avatar
sry for the threadjack but i have a question that goes along with this thread...i have a s5 and i was going to use the RB pre-silencer with the hook up for the 5th and sixth port so the exhaust will open them....is tha good????? i dont feel like trying to wire them open and i plan on getting rid of the pump
Old Dec 3, 2007 | 11:19 AM
Roen's Avatar
You need to retain your air pump, otherwise, your 5th/6th ports don't open.....read the post above you next time before posting. Or do some research into this, these topics have been covered 10000 times.
Man, I wish I was a mod so I could close redundant threads.
Old Dec 9, 2007 | 08:00 PM
yudaya's Avatar
sorry about asking redundant questions ROEN but i went to search and tried a few different variations of my question and all i ever get when using the search is no matches found, ive also scrolled through countless pages of treads and found nuthing. but thanks for the help anyways!
Old Dec 9, 2007 | 08:37 PM
Roen's Avatar
sorry for sounding like an ***, but for a street car, absolutely make sure that those 5th and 6th ports work, otherwise, the car will be a pig down low.
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Turblown
Sep 30, 2015 05:58 PM
m_haiser
Sep 13, 2015 04:21 PM
