Air Pump Question
Old Nov 25, 2007 | 04:04 PM
AreExSevenProject's Avatar
drift city
Air Pump Question
alright i have a question...
I hav a non-turbo and everytime a shift it makes sort of a blow off sound.
i believe (or at least think) that this sound is coming from the airpump hose...
i have them all just lying around going nowhere because i have aftermarket exhaust...
so my question is how do I make this sound louder...
and which hose is the intake to the airpump and which is the outlet...
Old Nov 25, 2007 | 04:07 PM
introVert's Avatar
putting it down daily
*dons flame suit and ducks behind banner*
Old Nov 25, 2007 | 05:00 PM
mazdakarate's Avatar
HOLY ****. I know where the sound comes from... I know you no longer will pass smog... I'm guessing the little tube that connects to the stock cat was left disconnected when you put in that FULL DUAL exhaust in. Don't just disconnect the hose to ur airpump... Also I know you may want to put a BOV on the air pump... make sure u put the spring to the softest setting. GOODLUCK! jk don't do it unless you have the acv blocked off properly. Theres no point to this.. so wtf... uhh.. Post pics of this modification and make a write up!! it will be awesome.
Old Nov 25, 2007 | 05:09 PM
phoenix7's Avatar
your car is gonna blow up!
Old Nov 25, 2007 | 06:51 PM
Black Knight RX7 FC3S's Avatar
Turbo power, activate!
hahaha
pretty much, the front hose is the intake and the rear hose is the outlet.....
Old Nov 26, 2007 | 01:25 PM
drift city
my dad plugged the air pump hose leading to the exhaust...
so now i have a plug hose where it usually goes in the exhaust...
i have a feeling this is not good for the air pump...
but im gonna make something that would blow off the air.
ill put pics up after
Old Nov 26, 2007 | 02:09 PM
rx7fc3s87's Avatar
That's the riciest statement I've ever heard. You want to make it louder? Take the damn thing off.
Old Nov 26, 2007 | 02:12 PM
aznpoopy's Avatar
strike up the paean
yo son that **** is mad tyte
all the noise none of the power
word to drift city
Old Nov 27, 2007 | 05:55 AM
his daddy did the work...
Old Nov 27, 2007 | 06:39 AM
w0ppe's Avatar
CC of L-Squared Shots
You know, Ricers and RX-7s DON'T MIX!!!
The Rotary engine will not stand for it (It will self-destruct should you feed it rice)
Feed it oil and it'll be happy!
Old Nov 27, 2007 | 09:01 AM
Hello Roto's Avatar
El Mas Tiguere...DR
uh..... speechless
Old Nov 28, 2007 | 10:01 PM
drift city
haha
i know ima ricer...
i just think it sounds tight and i want to hear more of it....!
Old Nov 28, 2007 | 10:23 PM
xUnKnOwNx's Avatar
haha
i know ima ricer...
like w0ppe said. if your a ricer, dont get a rx7. you should get yourself a civic and rice it out all you want...
Old Nov 28, 2007 | 10:24 PM
Vert7's Avatar
sell ur 7 and buy a civic w/ custom cherry bomb exaust
Old Dec 2, 2007 | 10:15 PM
drift city
Naw i was asking this question just cuz my brother was talking about it...
doesnt mean i was going to do it...
im converting mine to a S5 13B turbo...
so then i can get a nice clean bov sound
no rice for me....
Old Dec 3, 2007 | 06:29 AM
AUGieDogie's Avatar
haha
i know ima ricer...
You just said you were a ricer and now you say you are not? what the ****?
Old Dec 3, 2007 | 08:31 AM
pfsantos's Avatar
(blank)
I'll go against the current and actually help you with the ricer project. The rear hose coming off your air pump leads to the ACV intake at the front. The hose at the back of the lower intake manifold goes to the cat and comes from the ACV split air passage - this is the one that is blocked off as you said - keep in mind you need air to it if you have a cat still. The ACV dump to atmosphere comes out of the ACV pipe pointing to the right shock tower. In factory configuration, there's a hose connected to it and leads to two silencers, one of which is mounted below the right headlight. If you can hear the sound, your ACV probably doesn't have this hose connected - that's where the sound is coming from when you let off the gas.
If you want to make the sound any louder, maybe a hose coming out of a hole in the hood or a microphone tapped into your sound system will do the job. Enjoy!
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
