Quick help w emissions
Old Nov 21, 2007 | 05:43 PM
incubuseva's Avatar
Boost knob
So I have a 91 NA w SAFCII, pace setter header, stock cat, apexi dual N1 + apexi cone intake.
I failed one section of the test. HC ppm during driving. Required is 150, the first test I got 228, the second test I got 368.
During the first test in 2nd gear going about 3k I had the SAFCII set to -20%. The second time I was in 3rd gear about 2k + set to -10%
So I got some new plugs, gunna instal those soon. What else should I do to help out? My air pump + everything is working, so adding another won't do much. I also have some thicker MSD plug wires that I installed about a year ago.
Any suggestions? Thanks.
Old Nov 21, 2007 | 06:13 PM
phoenix7's Avatar
put the stock header back in? search the alcohol trick.
Old Nov 21, 2007 | 06:57 PM
misterstyx69's Avatar
Retired Moderator, RIP
sounds like your Catalytic is Toast..and it could be,due to the Header.Probably be better off to put in the stock manifold and get a high flo cat..or another NEW stock catalytic. NOW,the alcohol trick is to put in a Gallon of Denatured alcohol to two-three gallons of Fuel.(J-Rat had a Thread on it.).If you can't find it,try Methyl hydrate...One of the Tricks of the Emissions test is to Get the Car HOT..Drive the car about Twenty minutes..then before you get into the Test Area,Pour in the Mix and then get Tested..The "WARNING" about this,is that the Alcohol or "additive:" is not very Friendly with Seals.So you can Dillute it By FILLING UP,Immediately after the test..you shouldn't run the car on the Mixture any more than you have to.I hope that may help you out a bit.
Old Nov 22, 2007 | 01:39 AM
incubuseva's Avatar
Boost knob
Shoot. I don't have any of the stock stuff. I'll have to buy a new cat then.
Should it pass easily with that?
Old Nov 22, 2007 | 08:24 AM
Noel Caraballo's Avatar
the stock header plays an important roll when it comes to emmisions, try ebay if no one here can sell you one,
Old Nov 22, 2007 | 02:37 PM
phoenix7's Avatar
or borrow one
Old Nov 23, 2007 | 12:21 PM
incubuseva's Avatar
Boost knob
What about a new cat? This one looks like it will fit (has the pipe for the air pump too) http://www.partsamerica.com/ProductD...pe=145&PTSet=A
Or there is the mazdatrix one that is 'high flow' + 421 bucks. But I just need it to pass emissions then I'll probably gut out my old one + put that back on.
Old Nov 23, 2007 | 12:35 PM
incubuseva's Avatar
Boost knob
I need to have this done before the end of the month so that I can get my tabs.
ls1swap
Jun 3, 2024 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
