Turbo question
Old Nov 20, 2007 | 05:29 PM
jm93rx7's Avatar
Committee Member #3
Turbo question
I have a buddy that did put an S4 tii motor in his FB. He now switched to a holley carb set up and still running the stock turbo. the intake manifold that he is using doesnt have a place to hook up the coolant line for the turbo. His motor is stripped down to the bare essentials and is just planning on blocking off the coolant lines for the stock turbo and not using them at all. How safe is this for the turbo?
Old Nov 20, 2007 | 05:34 PM
veedubbed's Avatar
I have been running no coolant through the stock turbo for about 2 months now. It's working out fine for me - just make sure you are using a turbo timer or let the turbo cool down after driving it hard.
Old Nov 20, 2007 | 05:35 PM
stylEmon's Avatar
FC since 99
i'd say with the heat generated by the 13bt, along with how close the turbo is to the exhaust ports, you NEED the water cooling.
jm93rx7's Avatar
Committee Member #3
thanks for the reply. I will relay the info.
Old Nov 20, 2007 | 05:38 PM
veedubbed's Avatar
If you switch to an aftermarket turbo, chances are you won't even have an option for water cooling. It is utilized on stock turbos to keep them cool enough when driving hard (in stock form).
Old Nov 20, 2007 | 05:40 PM
jm93rx7's Avatar
Committee Member #3
this is only going to be a temporary thing while the motor is going through the break in period. After the motor is broken in hes going full aftermarket turbo.
Old Nov 20, 2007 | 05:42 PM
stylEmon's Avatar
FC since 99
when i go big turbo, I'm probable getting one that is both water and oil cooled.
should be alright for a small period of time
hotshot2014
Jul 18, 2017 02:30 PM
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
