car wants to start but wont
Old Nov 19, 2007 | 07:41 PM
firstgen689's Avatar
new plugs good wires timming might be off just a little... i think it is either getting to much air or not enough fuel..... i have most of the egr and the air pump holes caped off so really i think it is a fuel issue im ussing a carter fuel pump that i bought a napa and i dinki plastic filter but what i am wondering is i am not getting maybe enough backpressure or something because the fsm on my se calls for a high pressure side rather large fuel pump would that be the problem
Old Nov 19, 2007 | 07:44 PM
Siraniko's Avatar
RX for fun
so basically, it cranks but wont start...
Pull your plugs and see if they are wet. then report back
Old Nov 19, 2007 | 07:47 PM
already did they had a wet greasy looking carbon after cranking for a while (they are new by the way) it will start with starter fluid (probablly bad idea there) other than that with just gas every ones inwhile during crank generaly right off it trys to start..... al that is why i think it is a fuel issue
Old Nov 19, 2007 | 07:53 PM
ckm110789's Avatar
if its running off of the starter fluid and once it burns that off the car dies its a fuel issue.
Old Nov 19, 2007 | 07:57 PM
yeah thats what i said but lol but thanks at least that makes two of us
Old Nov 19, 2007 | 08:01 PM
Siraniko's Avatar
RX for fun
Do you know how to de-flood an engine?
Old Nov 19, 2007 | 08:06 PM
85 FB's Avatar
7-less
Go to State Farm and get some Flood Insurance?
Old Nov 19, 2007 | 08:17 PM
no how do you de flood it
Old Nov 19, 2007 | 08:18 PM
RXJIM's Avatar
The starter fluid might have washed some oil film out of the housings. Try putting oil in the spark plug holes.
oh also i pretty sure i have gas in the oil
how much oil just a few drops
Old Nov 19, 2007 | 08:22 PM
RXJIM's Avatar
Not a whole lot. If your using a funnel I would say about 1/4 of a quart total for both rotors.
Old Nov 19, 2007 | 08:24 PM
ok thanx you think that is why it wont start
Old Nov 19, 2007 | 08:42 PM
RXJIM's Avatar
It's worked for me before.
Good luck
Old Nov 20, 2007 | 04:35 PM
85 FB's Avatar
7-less
Whenever my engine flooded the only "quick" way I found to deflood it (this is a 13B) was to just crank it over a few times, let it rest, crank it over a few times, pump the gas pedal a few times, rest, crank and fuel, and after awhile it sputters to life.
Probably not THE best way to deflood it (I believe the Rotary tech guy told me that removing the plugs would work) but I've only had to do it like two or three times before.
Old Nov 20, 2007 | 04:45 PM
Siraniko's Avatar
RX for fun
he is correct also but its not 100% enough to start a severely flooded engine. You have to pull the plugs and crank away with fuel pump disconnected.
Old Nov 20, 2007 | 04:52 PM
85 FB's Avatar
7-less
I'll keep that in mind next time it happens. However, one thing he did suggest to me is to put in a fuel cut-off switch so that I can just flick the switch, turn the fuel pump off, and let the engine burn out the rest of the fuel. To ensure I don't flood.
Old Nov 20, 2007 | 04:54 PM
'84-12A-GSL's Avatar
Like a petcock on a dirtbike? LOL!
Old Nov 20, 2007 | 04:57 PM
85 FB's Avatar
7-less
Just a simple rocker switch hooked inline with the power wire leading to the fuel pump.
Old Nov 20, 2007 | 05:08 PM
Siraniko's Avatar
RX for fun
do it on the negative side so you dont have to worry about shorting issues.
Old Nov 20, 2007 | 05:09 PM
85 FB's Avatar
7-less
Ah, okay, thanks for the tip.
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
torky007
Aug 17, 2015 05:14 PM
