Like LS1, but is an LS2 much harder?
Old Nov 19, 2007 | 02:33 PM
G Gilla's Avatar
Well i have owned an rx7 for about 4 years and i am getting to that point were i am tired of putting all this money into it for the smallest problems. I have been looking at some LS1's and how hard it is to do a conversion. Just the other day i found a good condition LS2 motor out of a 06 GTO with about 20,000 miles on it. I just wanted to know how much harder and expensive to do a swap on a 93. What are some of the major problems that come along with this kind of swap. I know the LS1s have been getting easier and easier to do, But what about an LS2?
Thanks
-G Gilla-
Old Nov 19, 2007 | 02:38 PM
lt1_rx7's Avatar
Can I be the Emperor?
Veteran: Marine Corp
as far as i know the external dimension of the LS2 are the same as the LS1, so the same kit will work to install it. A few things I could think of that would differ some would be some wiring, sensors, and ECU...but I've not tackled the LS series v8s yet...
Old Nov 19, 2007 | 02:47 PM
G Gilla's Avatar
I havnt really thought of an LT1. How much do those motors run? And what is the power difference between the three
aaron1017's Avatar
Magic Triangles no more!
Major difference is the electrical.
Head to http://www.v8rx7forum.com/ and start reading! You are going to little... if ANY help over on these forums..
I am currently going ls1 @ the moment. Same username over there...
Old Nov 19, 2007 | 02:49 PM
G Gilla's Avatar
Thanks, the search function didnt really find much, ill take a look
Old Nov 19, 2007 | 06:23 PM
LT1's aren't half as good as an LS1, plus their igntion system (Optispark) is junk. An LS2 would be an identical swap compared to an LS1. I don't know of a single person who would actively try to put an LT1 into something.
Old Nov 19, 2007 | 10:40 PM
Troux's Avatar
I'm working on an LS2 project, though I don't have the motor test-fitted myself, but from reading, here's what I know:
1. The same subframe can be used, as mounting points are the same.
2. The oil pan must be changed. The GTO oil pan is a front sump, so you have to get a rear sump pan. Cheapest option is the LS1 F-body pan. This is also the only one that will work with Hinson's kit. Best option overall is a Corvette LS2 oil pan. It has improved baffling, and will fit just fine with Dynotested's kit.
3. The LS2 uses a drive-by-wire throttle. You either have to buy a gas pedal assembly from a GTO (can usually be included with the full pullout if you're buying through a junkyard, but you'll have to ask), and then buy the mounting kit to put the pedal into the 7 (from Hinson for about 100, give or take $20), or you have to convert the throttle body to a cable-driven unit. I'll let you do your own research on this choice.
4. The GTO tranny has a different shifter location than the F-body. Supposedly some people think the GTO location is perfect (F-body tranny requires minor cutting), but Hinson told me I'll absolutely need to buy his relocation kit ($60, give or take $20), which moves it to the same place as the F-body shifter).
5. From those I've talked to, I've heard the LS2 harness is actually a good bit EASIER to mod than the LS1 harness, although there are more people familiar with modding the LS1 harness.
These are the only differences I know of that you'll encounter. Good luck. Go LS2!
Old Nov 19, 2007 | 11:24 PM
LT1 RX7's Avatar
No doubt the ls series engines are superior to the lt1. However the lt1 is much cheaper to do. I paid $2500 for an lt1/t56 combo about a year and a half ago. Just got it running last week. It totally rips. I would let your budget be your guide. Check ebay for the differences in price and go from there.
Old Nov 20, 2007 | 12:36 AM
XxMerlinxX's Avatar
Team Benjos Captain
I've got a friend that had an LT1 in his camaro. Had SO much trouble from the optispark, he ended up selling it.
Old Nov 22, 2007 | 08:26 PM
books's Avatar
If you go LS2 with the Hinson subframe, you'll need some LS1 F-body engine mounts. Also if you use the GTO T-56 you'll need a F-body tranny mount.
Old Nov 22, 2007 | 11:00 PM
G Gilla's Avatar
There is this guy near me that wants 2 grand for the motor. So I thought I would go check it out. That sounds like a good price.
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
gabescanlon
V-8 Powered RX-7's
Sep 24, 2015 03:41 PM
BUSTN
V-8 Powered RX-7's
Sep 2, 2015 04:39 PM
