S400 Turbo Parts Here
Old Nov 8, 2007 | 07:11 PM
Viking War Hammer's Avatar
*** Bless The USA
After doing alot of researching, measuring and google searches......... I've found part numbers for the 5.75 inch V-Band Clamp and Flange. I know people advertise them but they want too much for them.
http://www.interstateturbo.com/Exhaust/Page19.pdf
V-Band Clamp Clamp also fits a T-50, VT50 and HT3B . Interstate Turbo Part # IT 88-506 , Manufacturer # 186917, Air Flo Part # 88-506 www.airflo.com price $20.03
Flange Interstate Turbo Part # IT 88-503, Airflo Part # 4388-503 www.airflo.com, price $10.59
Other S400 relative parts
5" OD OD dia. $9.42 per foot - part#STL3
Short Radius 90 O.D. leg length 5 1/2" $50.95 - part#433-500
Short Radius 90 O.D. leg length 7 1/2" $39.66 - part#434-503PE
Short Radius 90 O.D. leg length 15" $46.92 - part#434-515PE
Short Radius 45 O.D. leg length 12" $36.57 - part#434-545-12PE
Standard 45 O.D. leg length 6.3" $33.91 - part#432-5458PE
Standard 45 O.D. leg length 14" $42.07 - part#432-5458-14PE
It's possible to get it cheaper with further research and calling around to trucking companies but I'm tired of searching.
Old Nov 8, 2007 | 07:12 PM
*** Bless The USA
The search for the compressor outlet flange and v-band clamp is next.
Old Nov 9, 2007 | 12:55 AM
ZAN_TUNING's Avatar
Just turn up the boost!
damn man, nice work!
Old Nov 9, 2007 | 06:58 AM
RotorRican's Avatar
Rotary Loco
Talking
Yu Da Man!
Old Nov 9, 2007 | 08:47 PM
jccNV's Avatar
you got pics of the turbo
Old Nov 9, 2007 | 08:54 PM
*** Bless The USA
Old Nov 9, 2007 | 10:08 PM
mike_rudy's Avatar
Thats a massive turbo for a rotary, i run that as the second turbo in my compound setup at 50psi on my 12v cummins. It hakes a good reliable 450hp and 1100ft/lbs torque.
Old Nov 9, 2007 | 11:30 PM
WhiteStripesWS6's Avatar
That LS1 guy...
Is that like the little small size jar of peanut butter or is that turbo really that huge?
Old Nov 10, 2007 | 03:23 AM
ZAN_TUNING's Avatar
it's that big
Old Nov 10, 2007 | 11:41 AM
Doc Holiday's Avatar
Needs more cow bell
Old Nov 10, 2007 | 07:10 PM
jccNV's Avatar
wow that is nice
what is the exhaust a/r ?
Old Nov 10, 2007 | 09:02 PM
*** Bless The USA
Originally Posted by Doc Holiday
Good to see you posting. How have you been ?
Old Nov 11, 2007 | 12:38 AM
Needs more cow bell
Pretty good. I'd be a lot better if I could get my chassis guy to work on my car. 6 months later and its still there. I think maybe he doesnt like me.
Old Nov 11, 2007 | 02:04 AM
mike_rudy's Avatar
With a huge street port when would this thing start to boost? Is it the 1.32 a/r exhaust side?
Old Nov 11, 2007 | 02:10 AM
Archie's Avatar
Right-Wing Extremist Vet
Dude, I wish I could have saw this before I left. Your car is going to need landing gear, jesus.
Old Nov 11, 2007 | 05:05 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Can anyone post links that provide information on holset turbo nemoculure. if these are really that inexpensive, id like to see what they have to offer
Old Nov 11, 2007 | 05:32 AM
moremazda's Avatar
Gone Race'n
^^^ They are really that cheap, Holset documents are pretty hard to come by however. I have an H1E which are ~$550 brand new from City Diesel.
Isn't the S400 made by Borge Warrner?
Old Nov 11, 2007 | 07:33 AM
mono4lamar's Avatar
In the burnout box...
Is that s400 a ball bearing setup? I bet not for that price but it's worth a shot! How long will they have that pricing in effect? I want to build a 20b maybe next year or further...
Old Nov 11, 2007 | 09:36 AM
13B-RX3's Avatar
7s before paint!!!
Right off the line if you want it to. Most of the "cheap" ones are 1.32 A/R.
That is a Borg Warner turbo not a Holset. Here is a link that has a compressor map. Look under the technical info
Tab. http://www.citydiesel.net/b2-s400-tu...ml?cPath=32_34
No, it is a plain bearing turbo. For some reason the price keeps dropping. You can buy them very cheap.
http://majesticturbodallas.com/specials1.html
The place Eric found is still the cheapest. And for another $300 they will put a 80mm compressor wheel in it
Old Nov 11, 2007 | 05:19 PM
the s400 looks very similar, atleast wheel dimenions to a gt4202 does it not?
Old Nov 11, 2007 | 07:58 PM
Stanello's Avatar
backslash beanbagrace
S400 Turbo $482 out the door
Damn, and I thought I got a deal on mine.
Old Nov 11, 2007 | 08:25 PM
*** Bless The USA
Well, the guy was nice and gave me dealer pricing. A friend tried calling to get the same deal and this is what happened.
I talk to Jess yesturday he quoted me $950. Today I try again and it's $1100. If I were to call them again what do you think I should said?
I'm not sure if they were quoting him MSRP or what. They're a enormous dealer and have about 20 S400's sitting on the shelf among 1,000's of other turbos on shelves.
Old Nov 12, 2007 | 10:13 AM
mono4lamar's Avatar
Please someone elaborate! This should be superior in size to a 42r though not from a quality and longevity standpoint...
Old Nov 12, 2007 | 06:24 PM
S400 specs from City Diesel ---|--- GT4202R from garrett
Compressor Wheel Inducer 74.549mm 74.7mm
Compressor Wheel Exducer 100.1776mm 102.3mm
Turbine Wheel Exducer 88.0618mm ???
Turbine Wheel Inducer 95.7072 82.0mm
the s400 looks to have a larger turbine, but smaller compressor. just briefly looking at the comp map though, the s400 looks broader, which at the moment, im under if its a good or bad thing.
Old Nov 12, 2007 | 06:45 PM
*** Bless The USA
This is all I need to know.
Originally Posted by crispeed
It's basically the same size as the GT-42 using the T-6 turbine.
The S-400's offer more readily available choices in both compressor wheel and turbine housing sizes.
The major difference over the GT-42 would be the turbine wheel is much bigger more like a GT-45.
Have not seen a GT-42 make 900whp plus on a 13b but the S-400's have done it on many !
Originally Posted by rotor_dee
With the s400 i have run 7.62@173.
I have been using, and selling these turbos since the begining of time and recently have been blessed to be working hand and hand with Borq Warner Engineers since my race team is backed by Borq Warner.
