MSD ignition???
Old Apr 11, 2002 | 04:44 PM
dvls-7's Avatar
Sick & Twisted
Question MSD ignition???
Hey guys.....
Do any of u guys use MSD if so is it any good.....if not what other alternative do i use.....i recenctly acquired a MSD box basically for free.....(the guy got the wrong box for his car so i traded for it).....anyhow just wanted to find out if it is worth puttin on my 7.....thanks for your input.....
Da Omen....
Old Apr 11, 2002 | 05:09 PM
RETed's Avatar
What model MSD box?&nbsp There are a lot of them available...
-Ted
Old Apr 11, 2002 | 05:16 PM
jon88se's Avatar
Eat, sleep, work, mod.
I've seen MSD 6A boxes provide good results ona few ZX Turbo's before but I haven't driven a rotary that had one installed. From what I've read one box can be installed for what I assume is leading but some people do use them for trailing too. Not sure of the benefits of two versus one, especially in an NA vs. a Turbo model. Has anyone used HKS's twin power rotary box before? I just put one in my GVR4 a couple of weeks ago and it cleaned the idle up nicely and reversed the effects of the VPC and 550cc injectors. The mazda ignition is supposed to be really powerful though and very capable for a lot more power, correct?
Old Apr 11, 2002 | 06:12 PM
amemiya's Avatar
I have a 6al and it get a better smother idle and the plugs seem to stay cleaner. I only have it on the leading side I am going to upgrade to the DIS setup.
Old Apr 11, 2002 | 06:25 PM
E6KT2's Avatar
This month's Car Craft tested the MSD, Crane, & Accel and found them all to be EQUAL on the dyno. >1% difference between the three.
Old Apr 11, 2002 | 07:45 PM
dra_gon_lee's Avatar
hey amemiya... if your up grading soon hows about you sell me your old one?
i need something to clean up my idle, and light off those backfiring, richass rotors hehe
Old Apr 11, 2002 | 07:49 PM
bingoboy's Avatar
Lava Surfer
i emailed msdtech and they told me i'd need 3 of their ignition boxes or one box and something else added to it to work properly for a rotary. i didn't ask for more info on it, but if you email them and ask for the schematics of the setup they will fax you the diagram.
Old Apr 11, 2002 | 08:38 PM
jon88se's Avatar
One box can be used though, people have done it with good results. However, at the price of 3 MSD's to work "properly" the HKS unit seems a lot more cost worthy. What about that jacobs rotary pak, anyone using it??
Old Apr 11, 2002 | 10:56 PM
allstyle's Avatar
Me...me...me
I have the 6A Model. Gas mileage is up....exhaust smells cleaner...crisp bottom end....and mad top end!
Old Apr 12, 2002 | 08:14 PM
amemiya's Avatar
you need 3 6a or 6al boxes one for leading and one for each trailing. if you get the msd DIS box it will do all for just one box.
Old Apr 12, 2002 | 08:17 PM
RETed's Avatar
You guys never learn.&nbsp An MSD DIS box CANNOT control all 3 ignition channels.
-Ted
Old Apr 12, 2002 | 08:26 PM
amemiya's Avatar
well guys looks like we are going HKS
Old Apr 12, 2002 | 08:38 PM
Bambam7's Avatar
I came, I saw, I boosted.
Nope.... some guy learned the hard way, and was stuck with the DIS, since most places wont return electrical items!! An expensive mistake!!
They won't work!!
As for MSD results... I have a noticably smoother midrange, idle is the same... if not worse?!!
Power? Same... maybe a tad better in the midrange, but definately smoother.
I noticed more of a difference in how well the car ran by changing to MSD 8.5mm wires, than I did with the MSD. You should usually change both at the same time.
Old Apr 12, 2002 | 10:13 PM
jon88se's Avatar
I think I'll get another HKS twin power like the GVR4...besides, it matches the Tein pillow ball mounts in gold and thats REALLY what matters, ain't it?
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
