cornerweighing my FD - a work in progress
Old Nov 5, 2007 | 07:11 AM
2MCHPWR's Avatar
FD / LSX
The new coilovers are in and I took car for a spin today and they felt insanely great. I can't believe 900 lbs springs can feel so good. Not jarring at all. The car needs an alignment but it still felt good enough to drive around. No pulling or shaking.
So I put her on the corner scales tonight to check the starting points.
Notes:
-ride height is off as you'll see, mostly in the right rear. That is because I just bolted them in from the car I got them from.
-sway bars need to be disconnected before doing any adjusting. So these numbers are skewed slightly.
Results:
I will use this page as what steps to follow on how to adjust (I posted 2 links in other thread but they are good): Understanding Corner Weights - How To - Hot Rod Magazine
This one looks good too:
Grassroots Motorsports » Understanding Corner Weights
I'll update this week with how I adjust and how it changes the weights.
Old Nov 5, 2007 | 07:37 AM
BoostedRotary's Avatar
I have also recently corner weighted my track FD, I dont have my sheet with me for exact measurements but with myself and 1/2 tank of gas it weighted in at 1278 kgs with a perfect 50/50 distribution and 320,5kgs on each wheel.
Old Nov 5, 2007 | 08:40 AM
ptrhahn's Avatar
Where'dya get those savory JRZ's?
Old Nov 5, 2007 | 10:19 AM
cabaynes's Avatar
Old and grumpy
please do update this thread.
also, which scales are you using?
Old Nov 5, 2007 | 10:24 AM
aznpoopy's Avatar
strike up the paean
congrats!
i believe it. get quality shocks and you'll have a quality ride, even with stiff *** springs
are you doing this yourself or at a shop? i've been looking for a local shop in jersey that does corner weighing
Old Nov 5, 2007 | 11:09 AM
ptrhahn's Avatar
Oh yeah, FYI, you probably don't really need those helper springs, the car will never see full droop condition on the road... I had the same question when I first put the GC's on.
Old Nov 5, 2007 | 11:29 AM
2MCHPWR's Avatar
FD / LSX
anzpoopy - i'm doing it myself. i borrowed a friends long acre scales. i have heard Will DiGiovani from Precision Motorsports is very good at this (908 832 - 6572). also TTP in northern NJ has started corner weighing too. www.ttperformance.net
http://72.14.209.104/search?q=cache:...lnk&cd=5&gl=us
thanks ptrhahn
Old Nov 5, 2007 | 08:43 PM
Troux's Avatar
Where did you get those coilovers? And how much were they?
Old Nov 5, 2007 | 08:46 PM
2MCHPWR's Avatar
FD / LSX
i got em used. but you can get em new:
http://www.jrzusa.net/products/
although an FD application isn't listed on the price list, they do make them special order:
http://www.jrzusa.net/prices/jrz_prices.pdf
Old Nov 6, 2007 | 09:33 PM
2MCHPWR's Avatar
FD / LSX
First Adjustment: I was told motion ratio was .6, so I took a guess on how many turns to lower the rear coilovers. There are about 10-12 rotations per inch. I took a guess to lower the Left Rear 5 turns and the Right Rear 6 turns, and it turned out perfect. Ride height at every corner is now 25.25 inches. Rear sway bar is disconnected but front is still connected. Still 1/4 tank of gas and I will put more in tomorrow night. That will improve the distributions I believe.
The main improvement is that the Cross weights ((RF + LF)/ttl weight) went from 47.8% to 50.2%:coolugh: As per those articles I listed, this is hugely important to be as close to 50% as possible. Mission accomplished.
Tomorrow I hope to do one more measurement by adding more fuel so its a real world weight, and by disconnecting front sway bar (in case there is preload).
I put all the measurements in a spreadsheet here:
www.ponycars.net/cornerweights.htm
I almost got killed because as I was jacking up the rear (fronts already on the scales), the front wheels were being pulled back and fell off the scales and the car rolled back and pinned my shoulders and head against my garage door. I wiggled out. Luckily the door is weak aluminum and dented in easily
Old Nov 7, 2007 | 10:30 AM
adax's Avatar
You're probably having the same problem in the rear that I had with my JRZ's in that the lower shock bolt is too short. I'd recommend the following solution before you loose it at a bad time.
https://www.rx7club.com/suspension-wheels-tires-brakes-20/custom-fd-rear-sway-bar-end-links-how-695989/
Alan
Old Nov 7, 2007 | 11:29 AM
aznpoopy's Avatar
strike up the paean
be careful man.
you should really throw some kind of ballast in the driver's spot to simulate your own weight.
edit: nevermind i see it says with driver. i'm seriously having a problem with glossing the reading. i blame school.
Old Nov 7, 2007 | 09:36 PM
2MCHPWR's Avatar
FD / LSX
done finally.
added 9 gallons of fuel (gained 58 lbs).
no driver, all swaybars disconnected, 2825 lbs, 49.9% front, 50.1 rear.
With driver, 3033 lbs, 49.2% front, 50.8 rear.
did it on garage cement slab floor. i think its pretty flat. i'll check on another spot but for now, its good enough. rearward weight bias
Old Nov 8, 2007 | 09:09 PM
2MCHPWR's Avatar
FD / LSX
ponycars.net
the yellow highlights are when i took the measurements front headed in versus backed in. since floor isn't flat. i took the averages and with me in, front is 49.45% and rear is 50.55%.
Old Nov 9, 2007 | 10:18 AM
owen is fat's Avatar
holy crap man that must have been not fun.
at least throw a tool on the scales to act as a wheel-chock the next time you do any stuff like that, wow.
gives me the shivers.
nice final results though, awesome, you have to be totally stoked on those coilovers, such a nice product.
Old Nov 9, 2007 | 12:16 PM
student13b's Avatar
poor student!!
nice good thread im planning to do the same this next year!
Old Nov 10, 2007 | 12:13 PM
adax's Avatar
I PM'd 2MCHPWR my cornerweights but I also thought it might be helpful to post here as well for others. This data is for a single turbo '93 with 3/4 tank of gas, me (180#) in the driver's seat, and a Kirk roll bar as the only weight-adding mod. Sway-bars disconnected. Sorry it's not in the cool spread-sheet form but you get the idea.
Weights in pounds
LF = 739 RF = 673
LR = 830 RR = 763
LF + RR cross = 1502 (49.9%)
RF + LR cross = 1503 (50.1%)
L = 51%
R = 49%
F = 47%
R = 53%
Total weight = 3006
F = 5 caster, -1.8 camber, 3 mm toe in
R = -2.0 camber, 5 mm toe in
ItsJBohmzB
171
Apr 24, 2017 01:11 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
Ciclovnz
18
Nov 26, 2015 04:35 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
