it wont start please help i have no ride
Old Apr 10, 2002 | 09:43 PM
krazie2insane's Avatar
i dont know what the problem is but when i try to start it it just clicks and there are 2 wires coming out of the back of the tranny that are red and the only ones they can connect to are the 2 that are red and the other one is black help me hat are they
Old Apr 10, 2002 | 11:44 PM
Keith's Avatar
Can't help on the tranny. However, for the no start problem, I would jack up the front drivers side of the car. Have someone try and start the engine while you have a meter on the small wire to the starter. You should see 12V there. If this is good, replace the starter. Otherwise, post back and we will help you troubleshoot the starter interlocks.
Irv, Keith's dad
Old Apr 10, 2002 | 11:48 PM
hyperdaddy7's Avatar
make sure your battery terminals are clean and are making a good connection.
as for the wires i have no idea what you are talking about.
Old Apr 11, 2002 | 09:48 AM
try wacking the starter with a hammer a couple of times. it works for me
Old Apr 11, 2002 | 09:51 AM
PraxRX7's Avatar
hmmm
My car wouldn't start..battery was dead....everything is cool now though, recharged battery.
I'll be back on the road soon enough!
woa man.. Calm down and try to explain the 2 red wires again?
.. Have you taken the starter off recently ? did it just BAM stop working one day? Check it with voltmeter like mentioned above..
Old Apr 11, 2002 | 09:54 AM
Samps's Avatar
It may be your neutral safety switch. If your car is an automatic it must be in PARK or NEUTRAL to start. When my car used to be an auto the shifter would sometimes not go to the exact position and I would have to "wiggle it a lil bit" to get it started. If it's manual then maybe your clutch switch got disconnected somehow; and when you try and start the car it thinks you haven't pushed in the clutch. Have you tried bump starting it? Try a known good battery out of a freinds car.
Old Apr 11, 2002 | 10:23 AM
blu_gxl's Avatar
my car does some thing like this don't know about the tranny wires but sometimes (more than others) i turn the key and it just clicks and i turn and turn until it starts the starter in my case it's a bad connection to the ground on the battery (has happened on more than one car) try tightening the 2 bolys that hold the actualy wire to the terminal of the ground side of the battery. then clean terminals and if it still clicks just keep trying to turn the key eventualy it will start. if this is your problem, kinda sounds like it is. to find out how many times did you try the key?
james
Old Apr 11, 2002 | 10:41 AM
Icemark's Avatar
Wires/switchs on the manual tranny are for Neutral sensor, 5th gear sensor, and reverse lights.
They would have nothing to do with starting the car.
Old Apr 11, 2002 | 02:41 PM
f**kin right guys ill check that out and i appreciate it irv and everyone else i think it is a bad connection cause i think the negitive battery cable is grounded on the left starter bolt and i dont have it grounded that good so ill get back to yall and lt you know thanks again guys
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
gabescanlon
Sep 5, 2015 12:09 AM
rx7shirley
Sep 2, 2015 02:11 PM
