Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D anyone with write up on wireing 3d.v4 with cas
Old Oct 21, 2007 | 09:11 PM
dennis blackstone's Avatar
well i have a wolf 3dv4 and what do i need to hook it up with stock cas and coil packs has any one hooked it up with stock coils and cas any diagrams floating around
Old Oct 21, 2007 | 09:56 PM
nyt's Avatar
nyt
wow, how many times do we see this thread?
I've posted writeups and diagrams.
this forum doesn't have too many posts, try searching.
Old Oct 22, 2007 | 10:38 AM
thanks nyt ill look for it ...by the way was it a succesfull install
Old Oct 22, 2007 | 03:46 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I run a stock cas
Stock coils work but the ignitor will not unless you have ordered your ems flashed to allow it to control the overenginnered trailing ignitor
Just buy a FD ignitor, which is a 3 channel unit, and you can control all 3 coils from it, or just the trailing if you wish
CAS writeup
https://www.rx7club.com/showthread.p...ght=CAS+Wiring
Ignitor write up
https://www.rx7club.com/wolf-3d-125/howto-fd-igniter-wolf-3d-v4-389233/
g'luck, post more questions if ya got em, however most wiring thiings have been covered so feel free to search
Old Oct 22, 2007 | 04:05 PM
nyt's Avatar
nyt
+1 for fd igniter, i got one for $25
Old Oct 22, 2007 | 06:40 PM
just buying the one fd ignitor is all i need? for ignition and i wire that to the plug near the battery for the leading coil ,,,by the way i have a msd will that do it and how i wire that up ..sorry for all the questions i read a few post but my electronic skills suck thanks guys for any info
Old Oct 22, 2007 | 07:31 PM
nyt's Avatar
nyt
best ignition setup you can use is fc coils, fd igniter, and an msd 6a on the leading coils. imo
Old Oct 22, 2007 | 07:42 PM
nyt how do you put all thi together do you take the ignitor out of the fd boy im confused
Old Oct 22, 2007 | 08:15 PM
dont bother putting in the msd box yet, get the car running without it first
the second link has all the wiring for the igniter
Old Oct 22, 2007 | 08:24 PM
crackheadme do you have a pic of this im so lost with schematics or if you could draw it sorry for being so dum
Old Oct 23, 2007 | 08:51 PM
per nyt..
This is looking at it with the pins on the igniter facing up, looking at the top side of it. Pins from left to right. This matches up with the diagram on page G-16 of the FSM. Make sure you have the connector from the FD harness with the igniter also.
PIN 1 - Trailing Wolf (T1)
PIN 2 - To Trailing Coil (T1)
PIN 3 - Trailing Wolf (T2)
PIN 4 - 12V IN (switched)
PIN 5 - To Trailing Coil (T2)
PIN 6 - Leading Wolf
PIN 7 - To Leading Coil
PIN 8 - Unused (bridged to pin 7 inside the igniter)
from the FSM.
Old Oct 23, 2007 | 08:53 PM
so wire pin1 to wolfs' trailing 1 ignition output
pin 2 to the trailing coil
pin3 to the trailing coil 2 wolf output
so on and so forth
Old Oct 24, 2007 | 07:57 PM
crackheadme your the best thanks so much ....any info for the for wires on the cas..which wires from the wolf to splice into the cas connector
toplessFC3Sman
Mar 20, 2018 01:54 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
