160 lb Primary's on E85
Old Oct 17, 2007 | 03:30 PM
fritts's Avatar
Mad Man
Wondering if it would be possible to get 160 lb primary injectors to idle running E85. Assuming 30% additional fuel is needed. I'm upgrading my rails and injectors for E85 and the 160lb injectors are cheaper than the 95/100lb injectors and would give me more overall horsepower potential. Any thoughts?
Old Oct 17, 2007 | 03:56 PM
Viking War Hammer's Avatar
*** Bless The USA
I'm using (2) 1680 CC injectors for my primaries. It hasn't ran yet but, that's what I've got so it better work.
Old Oct 17, 2007 | 03:57 PM
crispeed's Avatar
'Tuna'
Idles perfectly and as lean as you want it to be with the right ecu or tuner.
Old Oct 17, 2007 | 08:24 PM
fritts's Avatar
Mad Man
I wasn't sure whether the duty cycle/opening on the injectors could be set low enough and be controlled enough to actually idle and idle at a decent A/F ratio 12.5-13. I am running a PFC currently I am having doubts it will handle the injectors though. I could not find it in a search but believe the PFC has a minimum ms of opening. Oh and I'm the tuner so that side shouldn't be a problem
Old Oct 18, 2007 | 03:52 AM
frode's Avatar
I am running 1680cc primaries on regular pump fuel (not E85).
Ecu is Autronic SM4 and the injectors are run in sequential mode.
Old Oct 18, 2007 | 09:32 AM
zinx's Avatar
_________________________
Interesting thread. I did some quick calculations. Take the 30% more usage on E85, i would use up about 4778 cc of injector to get the same power level as current. That would put me way over the 80% threshold. If i switched up to 1600 cc injectors all around, that would put me at 75 % duty on E85. That still doesn't leave much room to play. If i were to run E85 I'd like to at least raise the boost to 25 psi.
Code:
Injector	Duty cycle (pump)	Estimate Injector on E85	Duty on E85
4900	        75%                    	4778	                        98%
6400	        57%	                4778	                        75%
Old Oct 18, 2007 | 10:20 AM
fritts's Avatar
Mad Man
There's always the 2200 cc injectors at 150 each.
Old Oct 18, 2007 | 10:21 AM
zinx's Avatar
I'd need to add a reserve 20 gal fuel cell for that crazyness. I'd have to have all the E85 stations around indiana mapped out.
Old Oct 18, 2007 | 10:33 AM
*** Bless The USA
Code:
4900	        75%                    	4778	                        98%
6400	        57%	                4778	                        75%
From the looks of it, you're going to make more power with E85 on the same boost as you would on pump gas.
So, you need to figure out how much power you want instead of how much boost you want.
You can always add a few $50 bungs and buy some cheap 1680 injectors.
Anyhow, who knows. You might only need to add 20%. Looking at the E85 forum, people are running 20-30% more fuel. So, I don't think that 30% is set in stone.
Crispeed will have results this week so hopefully he can confirm or deny these rumors
Old Oct 18, 2007 | 10:36 AM
*** Bless The USA
Typical gasoline Thermal energy 19,000 BTU/lb max power fuel air mixture 12.5:1
Typical E85 Thermal energy 13,475 BTU/lb max power fuel air mixture 6.975:1
Typical ethanol Thermal energy 12,500 BTU/lb 6.429:1
If you are consuming 100 lbs of air, lets see how much fuel energy you release for each of these fuels.
100/12.5 = 8 lbs of gasoline @ 19,000 BTU/lb = 152,000 BTU
100/6.975 = 14.337 lbs of E85 @ 13,475 BTU/lb = 193,189.9 BTU = 127% more heat energy
100/6.429 = 15.555 lbs of Ethanol @ 12,500 BTU/lb = 194431.5 BTU = 128.9% more heat energy
Old Oct 18, 2007 | 07:05 PM
fritts's Avatar
Mad Man
Zinx you have to remember Portland Indiana (just north of Muncie) has the largest ethanol producing capabilities in the world. Not to mention the Bluffton Indiana plant (30 miles north of Portland) is going to be operational soon too. You being in Indy should be able to profit from this. Last I checked E85 was 2.39 a gallon where I live.
Old Oct 18, 2007 | 07:14 PM
*** Bless The USA
This is St.Louis, taken on the 13th
Old Oct 18, 2007 | 11:45 PM
fastrotaries's Avatar
W. TX chirpin Monkey
****...the few e85 places i've seen in MS/AL it .10 cents cheaper than 93 octane.
Old Oct 18, 2007 | 11:56 PM
*** Bless The USA
I'm surrounded by corn fields
Old Oct 19, 2007 | 06:08 PM
mcfly's Avatar
i live right beside one of the Canadian refineries making e85....we don't even sell it here
and pump gas is no cheaper regardless of the distance which sucks.
Old Oct 26, 2007 | 08:37 PM
btleier's Avatar
I have 850 primares, 1600cc secondaries, and dual walbro 255 pumps. 424whp at 18psi. idles just fine.
Old Oct 26, 2007 | 08:54 PM
fritts's Avatar
Mad Man
Sorry but I'm talking 1600 primaries not 850's. Could you give me the duty cycle, rpm and vacuum at idle, assuming this is E85.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
eplusz
15
Oct 7, 2015 04:04 PM
Jmolina0163
Oct 3, 2015 10:04 AM
