Will these FD rotorhousings fit my 12A motor ???
Old Oct 13, 2007 | 09:58 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Well I got these housings for cheap, no chromeflaking, perfectly straight and no crack at the sparkplugs.
I want to use them for my 12A blowthrough set-up, will it work, help a noob out
Old Oct 13, 2007 | 10:09 AM
Rx-7Doctor's Avatar
Quick answer, no.
12a plates with 13b 1st gen housings yes.
Old Oct 13, 2007 | 10:15 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
But how bout' them 12A rotors ?
Old Oct 13, 2007 | 10:40 AM
KansasCityREPU's Avatar
Out In the Barn
You need 13B rotors with 13B housings.
Old Oct 13, 2007 | 10:45 AM
-xlr8planet-'s Avatar
I has an emblem
13b engine rotor housings 80mm wide
12a engine rotor housings 70mm wide
12a rotors 70mm wide
quick answer no
BUT
A guy here machines 12a irons he makes the oring groove on them so you can use 13b housings.
Old Oct 13, 2007 | 10:48 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Are you sure?
Just ******' with you guys.
Cheap-*** mod of the day =
Had some fun with the Bridgeport CNC mill today
Ha ha I thought the o-ring grooves was a dead give-away.
I'll go sit in my corner now
Old Oct 13, 2007 | 10:51 AM
dbragg's Avatar
Say hello to Mr.Wankel
get some 2nd gen plates and GSLSE oil pan. use the 12a or SE front cover and youre good to go.
youll need a 13b rotating assembly though.
Old Oct 13, 2007 | 10:54 AM
I has an emblem
you have access to a CNC machine?????????????
I hate you Kim....
(envy, pure envy)
Old Oct 13, 2007 | 11:15 AM
nBOOSTe's Avatar
Yo Those Are Not "fd" Housings. Bro- Those Are 84-85 13b Housings Patna And You Cant Make Them Fit On A 12a Because The Only Thing U Can Use From A 12a For This Is The Plates Only. Other Than That Its Still A 13b
Old Oct 13, 2007 | 11:38 AM
Jeff20B's Avatar
Lapping = Fapping
That's very disturbing. Good luck with it.
Old Oct 13, 2007 | 11:40 AM
Kim's Avatar
Kim
OBEY YOUR MAZDA
How come that be disturbing, insight please
Kim
Old Oct 13, 2007 | 11:52 AM
1badFB's Avatar
GSSL-SE
Well, thats interesting.... haha
Old Oct 13, 2007 | 12:36 PM
NanaimoRx-7's Avatar
Holy ****, that's impressive. I'd like to see how it all comes together (if I can, I've never heard of doing that before), what is the benefit of the FD housings?
Old Oct 13, 2007 | 12:41 PM
BlackWorksInc's Avatar
Wrkn Toyota, Rootn Wankel
XD wait so you decided to machine the 13B housing down to 12A specs so you can have replacement housings?
Okay then I am gonna start laughing with amusement and be watching you to see how your crazy plan works out! ^.^ Brilliant! pure evil genius material here!
Old Oct 13, 2007 | 12:50 PM
diabolical1's Avatar
i'll be watching for updates on this, too. i'm particularly interested in apex seal life (exhaust port support makes me uneasy).
good luck with it though.
EDIT: actually, i take that back. i guess i've probably done some of my streetport 12A exhaust that wide ...
i still want to see updates when you put it together.
Old Oct 13, 2007 | 03:06 PM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Ha, I knew this would stir things up a bit.
Primary reason is: I had a hard time finding 12A housings that had no chrome flakeing, I am cheap like noone else, new 12A housings are wicked expensive overhere.
Secondary: Hey I saved an otherless scrap FD housing from the junkyard, these housings had some chromeflaking to begin with, but it does'nt matter since that part was ground away anyways.
I will update this thread when possible, got most parts right now to finish the build, but i'm also helping a friend out, building an endwall for his shop.
Have patience, grasshoppers
Old Oct 13, 2007 | 04:58 PM
trochoid's Avatar
Old Fart Young at Heart
Interestingly insane idea. Good luck with it.
Old Oct 13, 2007 | 06:36 PM
Directfreak's Avatar
I am a Jeeper Now.
Why not just build a 13B instead?
Old Oct 13, 2007 | 08:37 PM
I had heard the 12A housings were becoming more difficult to find in good condition. Would this be worth pursuing for anyone without access to sweet sweet machinery ? Or is only a good deal for you, you lucky lucky bastard
Old Oct 13, 2007 | 09:39 PM
steve84GS TII's Avatar
FB+FC=F-ME
Since when do FD engines have the water seal grooves in the rotor housings?
They look like 70's or GSL-SE rotor housings to me..........
Never mind......my fault for not reading the whole thing!
Old Oct 14, 2007 | 12:32 AM
Box_Man's Avatar
I hate drum brakes
Cam at Pettit racing used to do this for race cars that required 12As. The exhaust ports are also much wider unported than 12A ports, like a freebie port, and I think the spark plug timing might be different.
Old Oct 14, 2007 | 12:18 PM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Well, I could, I have all the parts for it, even a set of MFR P-port housings, so fun is just laying around my shop waiting to be plugged into a car
The thing is that when I've set my mind on something, It usually gets done sooner or later, usually later ha ha. Some time ago I saw a 12A blowthrough that Robert RotaryShack made, I'll admit that it tickled my interest to try the whole turbo thing.
I've allways been an N/A guy since my 86' GXL, homemade peripheral port 13B racecar[another thing I just had to try out, got two mfr housings that i copied timing off) to my S4 6-port FB.
Then one day I saw the light when I tried OC94Rx7's beautiful FD, boost is addictive like a drug, Roberts red turbomachine sealed the deal for me.
Old Oct 14, 2007 | 01:22 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
regrinding 13b housings to the same width as a 12a ones has been around a while now in Australia without any problems...i'll try to get some more info
Old Oct 15, 2007 | 09:02 AM
karism's Avatar
Adolf Hitler Verfechter
ok,weird,really weird.
But very interesting none the less.
Would like to see how it ends.You my friend,have ***** of ,umm haha Rotorhousings.
Karis
Old Oct 15, 2007 | 09:36 AM
680RWHP12A's Avatar
whats wrong with a 12a alex?! lol
kim, great idea..
