N/A engine to T2 tranny?
Old Apr 9, 2002 | 08:48 PM
autocrash's Avatar
Now with more 1st Gen!
Question N/A engine to T2 tranny?
So would it work to bolt a N/A engine to a T2 tranny bellhousing? is it direct bolt-in or are the blocks structurally different? ooh, and the clutch is different, right? so does it have a different number of splines as well?
I ask this because I want to do a N/A to T2 swap, but I want to do it slowly... ie. buy as many of the driveline parts as I can afford, swap 'em. Then build up a turbo motor (outside the car) and drive the hell outta my N/A motor. When it pops, or when I get the turbo motor done, swap it and the electrical... how does it sound?
Old Apr 9, 2002 | 08:54 PM
ACTION RT's Avatar
G35 FTW
Talking Hey dude
sounds fine,
im doing the same , but my engine or the funds won't be ready until winter.
Im doing all the big stuff during the winter. JUst want to drive it now, unfortunatly the stupid mto isn't off strike yet so i can't.
So did you get that black car dude??
post some new pics or email em to me man
rts36@hotmail.com
Action
Old Apr 9, 2002 | 10:19 PM
autocrash's Avatar
Well, I got half of it... so far. Hopefully I'm picking it up this saturday (april 13), but the guy has to get the ownership to me first... :O
I can't stand this waiting thing!
Old Apr 9, 2002 | 10:27 PM
FC Drifter's Avatar
Damaged Little F*cker
im pretty sure the T2 trans and the N/A motor do not bolt up. im not absoltley certain, but im 99% sure that it wont match up.
Old Apr 9, 2002 | 10:29 PM
TurboII RudeBoy's Avatar
Post count is over rated
yes they do bolt up,why wouldn't they thats stupid . i've seen i also while ur dingtat u might wanna get ur rear end mountwelded to the frame ,guarunteed to broken ount ever again.
Old Apr 9, 2002 | 10:34 PM
Icemark's Avatar
They bolt up, however you will need to change the starter, flywheel, clutch assembly, and clutch slave and build a custom drive shaft until you swap the rear end as well.
Old Apr 9, 2002 | 10:35 PM
amemiya's Avatar
ok here goes..
1.yes the trannys will bolt up.
2. No the t2 tranny will not fit in the N/A clutch (the spline has more teeth.
3. The t2 tranny needs the t2 drive shaft for the same reson as above.
4. The t2 driveshaft will not bolt up to the N/A diff do you will need the t2 diff.
5. As far as I know the axles are the same but I never tried it.
6. The t2 drivetrain is alot heavier and will make the car slower.
I hope this helps let me know if you have any question.
Old Apr 9, 2002 | 10:36 PM
amemiya's Avatar
7.oh yea the n/a clutch will not fit the t2 flywheel
Old Apr 18, 2002 | 11:33 AM
autocrash's Avatar
amemiya: thanks man, Thats about what I figured too.. if I do the swap it will be an entire T2 Driveline minus engine.... then I can build up the engine outside the car and swap it in when I'm good and ready ...so I guess I'll be a little slower for a while... but thats ok, I'll smoke all those ***** who pass me... when the new engine is in
Old Apr 18, 2002 | 11:36 AM
MaxRX7's Avatar
hambre y sueño
yeah. I agree with Icemark and amemiya.
Old Apr 18, 2002 | 11:43 AM
SonicRaT's Avatar
Super Raterhater
The half-shafts (axles) are *NOT* the same, they are about an inch shorter on the turbo. You could use the flange from a T2 rear-end and stick it on a NA rear end and use the T2 driveshaft with an NA rear-end, or so I was told, never tried it, but they measured out the same length when I checked. And You could use an automatic driveshaft if you were really crazy, because it doesn't slide in all the way.
rxmiles
Aug 24, 2015 02:07 PM
Wicked93gs
Aug 17, 2015 12:14 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
ncds_fc
Aug 15, 2015 10:06 AM
