just a question
Old Oct 10, 2007 | 03:31 PM
1991fc3sdrfter's Avatar
just a question
ive got a gt35r turbo. how much can the stock fuel system hold without over pushing them. i was just wondering
Old Oct 10, 2007 | 05:28 PM
wackaloo13's Avatar
dont turn it up past stock boost. there is no point in buying that turbo if you arent going to do all the supporting mods correctly.
Old Oct 11, 2007 | 10:41 AM
Jumbogumbp's Avatar
Stinky nutz!
UMMM first off psi doesn't = the same flow. If you were to put that on and ran it at the same "boost" you will probably run lean and blow your motor. A bigger turbo will push more air at the same boost level. It's pointless to put it on unless you do the supporting mods...
Old Oct 11, 2007 | 02:39 PM
wackaloo13's Avatar
get yourself a:
standalone
bigger injectors
new fuel pump
front mount
free flowing exhaust
better radiator
some AI if you are running higher boost
your motor is gunna go kablamo if you try cranking up the boost.
Old Oct 11, 2007 | 03:00 PM
bryant's Avatar
bryant
i had a t-78 with stock fuel system no problems but didnt boost past 10.
but it depends on the flow of the turbo.
Old Oct 11, 2007 | 03:13 PM
Jumbogumbp's Avatar
Stinky nutz!
well on an fd you might get away with 10psi on that turbo, I really wouldn't do it without at the very least upgrading the injectors and fuel pump... for some reason I thought the OP had an fc.
Old Oct 11, 2007 | 03:19 PM
bryant's Avatar
bryant
oops.
Old Oct 11, 2007 | 05:37 PM
oh sorry, yea i have an FD with a PFC, PWR radiator, PFS exhaust and i have a Greddy front mount on the way.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
