Junkyard Speed Shop
Old Apr 9, 2002 | 04:26 AM
Cool Junkyard Speed Shop
I'd like to see a thread where the parts most ppl pull out of the junkyard...i mean speed shop....for their rx-7's are listed nice and together. A shopping list, if you will, of things for which we should be on the look out. I've searched threads and heard of the 2nd gen alternator swaps, fb distributer swap, fiero fan mod, and the infamous lsd swap. However, since I've yet to do them, I'll let those experinced with the intricacies post. Just as an example tho:
DLIDFIS (Direct Fire Ignition):
'79 -
1 - 80-85rx-7 distributor/cap (81 - 85 would be best)
3 - J109 ignitors (81 - 85 rx-7)
3 - Ignition Coils (w/ 2 matching age, brand, etc.)
'80 -
3 - J109 ignitors (post 81 rx-7)
1 - Ignition Coils (3 total w/ 2 matching)
'81-85 -
1 - J109 ignitor (post 81 rx-7)
For a complete write up on DLIDFIS, goto Jeff20b's site.
I was not thinking complete write up's, but a compact collection of what's needed from the local 'speed shop' for various years. Or, if you don't know all the year's it'll work on, maybe state that. Then, possibly a link to instructions of the mod. I hoping it might collect enough centeralized information to get archived. Then, someone asks, "What are some cheap mods i can do to my rx-7, to make it go fast?" Bam! refer them to this Just a thought.
~ Ben
Old Apr 9, 2002 | 05:42 PM
82transam's Avatar
Never Follow
This is a really good idea I agree, anyone who has done a "common" conversion put a parts list up so we don't have to run to the "yard" 500 times to get the annoying little crap that everyone forgets to grab.
Old Apr 9, 2002 | 11:44 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah this is a really good idea. Dont think I can contribute much except for doing a cruise conversion on a 84-85, everything is prewired A 30 minute install!
Get the under hood actuator and cable
Get the switch for the dash
Get the new switch that mount on the cluster
And the little gold box on the drivers side behind the storage bin
Old Apr 10, 2002 | 09:33 PM
twister's Avatar
Great idea, I would love to be able to track down some online 'junk' yards!
Old Apr 10, 2002 | 10:02 PM
peejay's Avatar
Old [Sch|F]ool
5.0 Ford from a Mustang or Crown Vic/Grand Marquis/Town Car...
OW OW OW quit hitting me!
Old Apr 10, 2002 | 10:21 PM
79+80_rx-7's Avatar
Dont forget about those, T-birds..........
Damn, those rotor's HURT when they fall on you multiple times......
Old Apr 12, 2002 | 03:44 AM
Alright, after a little searching, I've gathered the facts myself for the mods listed above. I'm gonna list these in a somewhat logical order.
I'm assuming you 79 guys have upgraded your points to electronic ignition. What?! You haven't? well....
Fb Distributer swap
'79
80-85 distributer w/ ignitors (81 - 85 would probably be best due to more reliable ignitors)
81-85 coils
81-85 coil to ignitor wires
Go here for the full write up on installing your new dizzy.
Of course, it's never too soon to remove all the emissions. Click Me
Then, everybody do DLIDFIS (see above). You can also go MSD, but i thought we were going cheap. Because that RB exhaust and Yawpower carb cost ya $1100, you *have* to go cheap.
Now that you've found a few dozen ponies that were hiding under your hood, it's starting to get real hot in there. Yet you still want more HP? Fine, Next step:
Electric fan
79-85
1 V6 fiero electric fan w/ shroud (Others might also be sutable, measure and look around.)
That's it! You might wish to go to pepboys and get their electric fan wiring kit. Then, either get a switch, use your a/c switch, or others prefer using a thermostat switch to control when the fan is on. This info was cannabalised from various posts, but a pic of the fan installed ishere If all else fails, you can search the forum like i did to get all this info.
Now, that fan is pulling many amp's, and if you have a few other electrical things running (stereo, lights, a/c, etc.) You could be maxing out your alternator. Easy fix!
2nd gen Alternator Upgrade
'79 - '85
1 2nd gen alternator
89 - 91 = 80 amps
Right again, it's a Bolt in swap! All the details are here.
Now, some argue that you might need to upgrade your fusable links, and since your already getting under the hood of that 2nd gen you might as well swipe the fuse box as well. Besides the avoiding the danger of a fire, these fuses are far more availible than the links. Here we go again!
Fuse Box Swap
The fuse box off any number of cars.
Examples: 2nd gen Rx-7, 626, 323, etc.
Add in a few bits of wire, and there ya go! Details about doing this with the 2nd gen box are here, about half way down the page there is a full write up by Hanman.
Well, now you've got lotsa fuel, lotsa spark, what's missing...AIR! You could get a K&N air filter. Then you need to get cool dense air into your carb. Okay, this isn't really from the junkyard...but it's cheap, and DIY (do-it-yourself) Folow me
Hrm....Air, fuel, spark.... you should be running pretty well with everything you've done so far. Now you need to get that power down on the ground.
GSL(-SE) lsd swap
'79 - '80
'81-'85 LSD Axle (drum to drum)
- or -
'84 - '85 GSL-SE LSD axle (Disk to Disk) (If you want disk brakes)
'81 - '83
'81 - '83 LSD 3rd member
- or -
'84 - '85 rearend to get disks (3rd members will not swap into '81- '83)
'84 - '85
'84 - '85 3rd member
- or -
'84 - '85 rear axle to get disks
Here is a complete write-up on the compatability issues.
That's not good enough??? well...if you went ahead and got the 84 - 85 rear axle.....
Torsen Differential:
There are two ways to go about it...
1. The diff. assembly will bolt in to any 84-85 3rd member.
2. If you want to do a little grinding, You'll need to remove the upper link mount from the Miata aluminum housing and do some minor grinding to clear the Watts link bracket.
Find any '94 and up Miata with the R package or Touring package. Gear sets are interchangeable with the Rx-7.
Thanks Bobrx7
Now, these are the top improvements i know of to make our cars perform better. After these, you start going extreme. Ported engines, superchargers, turbos, little tiny nuclear reactors....you get the idea. However, if someone else has a trick they've pulled outta the junkyard, lets hear it!
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
cooldude
West RX-7 Forum
Oct 3, 2015 09:17 PM
