greddy type r wastegate diaphgram
Old Oct 1, 2007 | 01:07 AM
ALNY93R1's Avatar
Question greddy type r wastegate diaphgram
Does anyone know a reputable place where I can purchase a diaphgram and not wait 3 weeks for a drop shipment order?..
TIA
Old Oct 1, 2007 | 11:54 AM
mono4lamar's Avatar
In the burnout box...
Alex, are you sure it's the waste gate diaphragm? Did you pressure test it to see if it was leaking...?
Old Oct 1, 2007 | 12:42 PM
NiM0r's Avatar
check greddy's website, they have auth vendors who probly have the parts in stock.,
Old Oct 1, 2007 | 03:02 PM
ALNY93R1's Avatar
I'm pretty sure, diconnected all lines to the wastegate so I can run off the spring and I still get a spike at 1.2 bar@ half throttle. I have a new .80 spring in it with the tension screw all the way out. I will pressure test it tomorrow to be 100% sure.
Old Oct 1, 2007 | 07:12 PM
mono4lamar's Avatar
^ It's always better to pressure test wastegates before you buy new diaphragms. Sometimes the valve retainer nut gets loose inside...
Old Oct 2, 2007 | 11:52 AM
IRPerformance's Avatar
Sponsor
Take it apart and look at the diaphragm if you haven't already done so. I have seen them tear on several occasions with that particular wastegate. I recently replaced one for a customer. If you need it I can look up where I ordered it from.
Old Oct 2, 2007 | 02:06 PM
mono4lamar's Avatar
^There's no need to take it apart it it holds air pressure from a gun. If it leaks you replace it.
If you're going to take it apart the easiest way to check for a tear is to hold it over a light and go over it... If you see light or a strange light line it's time for a new one!
Old Oct 2, 2007 | 08:57 PM
Sponsor
Actually there is. The diaphragm will deteriorate and develop small cracks before it lets go completely. I have repaired about 3 of these so far. I learned this along time ago when taking one apart for ceramic coating. It still worked fine before that but it was only a matter a time before it would let go, and chances are it would be on boost. Easy way to blow a motor.
Old Oct 5, 2007 | 11:40 PM
Try these guys, they've come through for me before, outstanding customer service:
Garage GT
9285 Chesapeake Dr., Suite B
San Diego, CA 92123
(858) 505-8030
Ian_D
Oct 14, 2015 12:31 PM
