Ipod connection to FD factory radio?
Old Sep 24, 2007 | 08:02 AM
ppritchard's Avatar
93 Touring
Question Ipod connection to FD factory radio?
Has anyone come up with a way to hook up an ipod to the 3rd gen factory radio head? Thanks for any help.
Old Sep 24, 2007 | 01:52 PM
ZumSpeedRX-7's Avatar
rotary amuse
i use a Belkin docking station that goes into the cigarette lighter outlet and tune my radio to the station the belkin unit is on. it seems to gets the job done. i think you can also get a tape deck converter.
Old Sep 24, 2007 | 09:11 PM
DarkLikePoe's Avatar
It's dark like Poe.
No, but check out my thread on using a newer Miata headunit. Not only is the install pretty easy, but the options you get after installation are pretty nifty.
https://www.rx7club.com/interior-exterior-audio-26/fd-oem-bose-option-stereo-05-miata-probably-better-than-spirit-r-radio-687061/
Hope this helps!
Old Sep 26, 2007 | 05:44 PM
ppritchard's Avatar
93 Touring
when you say that you had to "split" the din to make the radio work, what exactly did you need to do? I see that there are two din connections on the back of the Miata radio, what went where?
THanks for the response and info on the Miata swap.
ppritchard
Old Sep 26, 2007 | 06:22 PM
FearNoPiston's Avatar
FREAK ALL OUT!!!
I think what he means is he had to cut the plastic bar in between the radio and the factory pocket. He also may of had to make a bracket for it, not sure on that part..... That would be a good choice if you want to keep the factory look....Or you can get a direct fm modulator, the wireless ones dont work very well and the direct ones are only 50 bucks. Or you might look at getting the harmon kardon set up that gives you a little screen and control that does the same as how your ipod operates. It also connects by a fm modulator that is wireless but you can by a piece that goes with it to make it direct. Oh also not sure if it matters but the headunit may only work if you have or dont have bose you check up on that before you decide.
Old Sep 27, 2007 | 10:17 PM
It's dark like Poe.
You've got a lot of options.
The install I did was a piece of cake, and getting my iPod hooked up to it ended up costing less than $80 total. No extra supports or fabrication was needed. You don't need to have Bose to make the mod work, you just need a newer, non-Bose Mazda headunit.
Old Sep 27, 2007 | 11:34 PM
SLOASFK's Avatar
Top's always down
Easiest way would be to use a car kit, though they tend to be a bit flimsy and wear out fast if you move the wire a lot.
Old Sep 28, 2007 | 04:03 AM
JSmith0101's Avatar
Play Well
An action shot.
Old Sep 28, 2007 | 06:25 AM
13bturbofc's Avatar
mmm doritos
WTF? i never knew the FD didnt come with a cd player im guessing it was a factory option but thats kinda dumb..my 88 vert even had a cd player from the factory...
Old Sep 28, 2007 | 07:41 AM
p4nc7's Avatar
Passenger
Looks like an FC to me. Neither of mine came with a CD player, pretty sad huh?
Old Sep 28, 2007 | 02:07 PM
13bturbofc's Avatar
mmm doritos
oh wait wtf that center trim threw me off i dont think thats even an rx7 is it?
Old Sep 28, 2007 | 03:09 PM
JSmith0101's Avatar
Play Well
It's an FB.
