Alternative Fuels Discussion and Tech on using alternatives such as E85 or Hydrogen or other fuels and/or supplements to Gasoline in Rotary Engines
Dyno results... 424whp @ 18psi on e85
Old Sep 18, 2007 | 05:16 PM
btleier's Avatar
I know I'd already posted the results in the e85 thread that I have going right now, but I thought I'd make a thread on my results from the weekend. I made the trip down to Sioux Falls, SD, and Joey from Excessive did the tuning for me. We were able to tune to 424whp @ 18psi. I am waiting for him to get back in touch with me on some of the details such as injector duty cycle, timing, a/f, etc. Mods are as follows:
Stock motor
Precision t4 pt67
sls custom manifold
sls vmount ic setup
tial 44mm wg
tial bov
aem ems
aem ignition
aem wbo2
850/1600 injectors
dual walbro fuel pumps
Be happy to hear your thoughts, and I'll post up the dyno sheet later today.
Old Sep 18, 2007 | 05:22 PM
13bturbofc's Avatar
mmm doritos
is this an fd or fc?
Old Sep 18, 2007 | 05:26 PM
Heisenberg's Avatar
Civilization is crumblin
Just out of curiosity. Were you monitoring EGT's? If so, what kind of levels were you getting?
Old Sep 18, 2007 | 05:28 PM
btleier's Avatar
fd.
Old Sep 18, 2007 | 05:33 PM
btleier's Avatar
no egt's were monitored this time around.
Old Sep 18, 2007 | 07:31 PM
13bturbofc's Avatar
mmm doritos
from what ive been hearing about e85 i am very suprised you had enough injector to run that kinda hp..i hear it takes ALOT of fuel to be able to run that high of boost with e85
Old Sep 18, 2007 | 07:32 PM
btleier's Avatar
it's more then fine.... running out of fuel wasn't even why we called it quits. I'll get injector duty cycles tomorrow for you guys.
Old Sep 19, 2007 | 10:18 AM
gusfd3s's Avatar
E85 Addict
Stock motor
Precision t4 pt67
sls custom manifold
sls vmount ic setup
tial 44mm wg
tial bov
aem ems
aem ignition
aem wbo2
850/1600 injectors
Peak and hold or resistors?
How far can you go with 280l/h pump and 850/1600 using resistors?
Old Sep 19, 2007 | 10:19 AM
btleier's Avatar
resisitors. I have the ultimate fuel package from Jason at rx7store.net.
I'm not sure what to tell you, my personal experience is only on dual walbro 255 pumps.
Old Sep 19, 2007 | 10:45 AM
wackaloo13's Avatar
How long have you been running the walbro pumps? They do not claim to be flex fuel rated. Also, did you replace the injector orings and such on your injectors or were they already flex fuel injectors?
Data logs of the runs would be awesome.
Old Sep 19, 2007 | 02:09 PM
btleier's Avatar
Old Sep 19, 2007 | 08:29 PM
AWD-RWD racer's Avatar
stock ports?
Old Sep 19, 2007 | 08:53 PM
btleier's Avatar
yes, stock ports.
Old Sep 23, 2007 | 10:03 PM
btleier's Avatar
be interested in seeing some more feedback in what other people have made on stock ports.
Old Oct 26, 2007 | 10:04 PM
btleier's Avatar
turbo crapped on me which is why I haven't been able to get you guys logs yet... turbo went off today, so as soon as I get it back I'll provide some more of you guys more info on my drive ability, and some logs to see how it all works with the e85.
Old Oct 26, 2007 | 10:57 PM
sk8world's Avatar
Chasing numbers
stock ports
glad to see you posting this info here. I have been wondering about this e85 but decided to wait to here more results as I do not want to be a tester.,. On the stock ports, thats great numbers. I made if I recall correctly 430 at 20psi area on a 40r (w/ stockports). But this was real lean, not as safe as I bet yours are..
Old Oct 26, 2007 | 11:03 PM
ErnieT's Avatar
Living life 9 seconds at a time
Very impressive. Congrats!
BTW...I made over 500rwhp on stock ports on my old red fd. Ari made over 600rwhp on stock ports.
Old Oct 27, 2007 | 02:03 AM
btleier's Avatar
I"m curious after all this dyno tuning, and having my turbo go out on me only a mile or so after taking it off the trailer, if my numbers are legit, or if that hurt my numbers. Also I have an intake temp issue. the shop that did my setup, didn't finish the v mount design, so my radiator is heat soaking my intercooler. so I need to get that finished, and get some sheet metal ducting in there. whatever little things could I look at to get my closer to my goal of 500whp without messing too much with my tune. what potentially could I pick up with a different lim. whatabout aftermarket uims? are any worthwhile? thanks for the feedback guys.
Old Oct 27, 2007 | 03:54 AM
point5chink's Avatar
are you using the 3ohm resistors that came with rx7 store? I tried those with my aem ecu and the ecu could not reliably control them at all. Half the time they just wouldnt do anything. I swapped to 10ohm resistors and all was well, i just had a whole lot of injector lag that i had to account for. Also, if you dont mind, i would be interested to see what your map looks like.
Old Oct 27, 2007 | 09:03 AM
How exactly did the turbo fail?
Old Oct 27, 2007 | 02:19 PM
btleier's Avatar
yeah I'm using the resistors that came with the rx7 store fuel package.
goodfella... my guess is it was a bearing failure. my compressor wheel hit the housing, taking chunkcs out of the wheel. when taken off the car, I could push from the back side, and move the entire center cartridge forward, and then from the front side push it back... had some definitely play. I'll find out exactly what's wrong, and what is gonna have to be replaced when I get the phone call from Precision.
Old Oct 27, 2007 | 02:29 PM
btleier's Avatar
and here are some pics of the setup. excuse the darkness of the pictures.
Old Jul 23, 2008 | 08:41 PM
kabooski's Avatar
Laying Down Rotary Law
did you get the injector duty cycle data yet?? its been a while now lol
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
